[GRASS5] errors building today's NVIZ
Maciek Sieczka werchowyna at epf.pl
Sat Jan 7 16:30:20 EST 2006
On sob, 2006-01-07 at 21:36 +0100, Markus Neteler wrote:
> On Sat, Jan 07, 2006 at 09:32:45PM +0100, Maciek Sieczka wrote:
> > On pi?, 2006-01-06 at 23:38 +0100, Markus Neteler wrote:
> > > On Fri, Jan 06, 2006 at 10:31:34PM +0100, Maciek Sieczka wrote:
> > > > Bob, All,
> > > > Building today'd Grass 6.1 CVS I have following error whwn compling
> > > > NVIZ:
> > <snip>
> > > > The last succesfull Grass 6.1 CVS build on my machine was 2005-11-16.
> > > Maciek,
> > > using google I found this one:
> > >  http://vtk.org/Bug/bug.php?op=show&bugid=1777&pos=0
> > > "VTK build failed due to:
> > > bin/libvtkRendering.so: undefined reference to `XF86VidModeQueryVersion'
> > > bin/libvtkRendering.so: undefined reference to `XF86VidModeGetModeLine'
> > > Those symbols are defined in
> > > /usr/X11R6/lib/libXxf86vm.so.1
> > > Problem #1:
> > > There is no: /usr/X11R6/lib/libXxf86vm.so
> > > Problem #2:
> > > We need to setup proper dependency
> > > Posted by: ******
> > > Date: 11:19 AM 04-18-2005
> > > Need a special package for that:
> > > sudo apt-get install libxxf86vm-dev
> > > Posted by: ******
> > > Date: 3:16 AM 04-24-2005
> > > Also Assign:
> > > /usr/X11R6/lib/libXext.so;/usr/X11R6/lib/libXxf86vm.so
> > > as the new value to the variable: X11_Xext_LIB
> > > Maybe it helps?
> > Markus,
> > Thanks. Unfortunatelly this doesn't help. I've already had
> > libxxf86vm-dev installed when compilation errors in NVIZ poped up.
> > See:
> > maciek at sorbus:~$ sudo apt-get install libxxf86vm-dev
> > Password:
> > Reading package lists... Done
> > Building dependency tree... Done
> > libxxf86vm-dev is already the newest version.
> > 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
> Did you also try the other trick suggested there?
> It seems to be a distro problem.
Indeed I haven't. Now trying it I can't get it to work - neither as user nor as root:
root at sorbus:~/src/straight/grass6#
X11_Xext_LIB=/usr/X11R6/lib/libXext.so;/usr/X11R6/lib/libXxf86vm.so
bash: /usr/X11R6/lib/libXxf86vm.so: Permission denied
Can you advice how to proceed?
P.S.
I can see this libxxf86vm-dev was installed on my system _after_ my last
successfull Grass build. Also my current kernel version was upgraded
then and kernel dev stuff was installed (for building alsa and ATI prop
driver most likely):
Commit Log for Sun Nov 27 14:15:33 2005
Installed the following packages:
libxxf86misc-dev (6.8.2-10.1)
libxxf86vm-dev (6.8.2-10.1)
linux-headers-2.6.10-6 (2.6.10-34.8)
linux-headers-2.6.10-6-686 (2.6.10-34.8)
linux-headers-686 (2.6.10-7.1)
linux-image-2.6.10-6-686 (2.6.10-34.8)
Upgraded the following packages:
linux-image-686 (2.6.10-7) to 2.6.10-7.1
Also the linux-image stuff was slightly upgraded on 2005.12.23:
Commit Log for Fri Dec 23 11:34:57 2005
linux-headers-2.6.10-6 (2.6.10-34.8) to 2.6.10-34.9
linux-headers-2.6.10-6-686 (2.6.10-34.8) to 2.6.10-34.9
linux-image-2.6.10-6-686 (2.6.10-34.8) to 2.6.10-34.9
Maciek
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
