[GRASS5] GRASS 6.0.2RC3 released
Scott Mitchell smitch at mac.com
Sat Jan 7 19:23:08 EST 2006
Great.  I can confirm that RC4 fixed the object file problem, and I
got a completely clean compile.  I'll run some tests tomorrow.
Cheers,
Scott
Scott Mitchell, Assistant Professor, Carleton University
Department of Geography & Environmental Studies, Loeb A209
Mailing:  Loeb B349, 1125 Colonel By Dr., Ottawa, ON K1S 5B6 Canada
1-613-520-2600 x2695 Fax: 613-520-4301 Scott_Mitchell at carleton.ca
On Jan 6, 2006, at 13:24, Markus Neteler wrote:
> On Thu, Jan 05, 2006 at 05:16:39PM -0500, Scott Mitchell wrote:
>> Strange, in trying out 6.0.2RC3, I'm getting a compilation error on
>> all machines that I haven't seen mention of:
>> [smitch at gracilis r.le.setup]$ make
>> Makefile:16: warning: overriding commands for target `clean'
>> ../../../include/Make/Rules.make:35: warning: ignoring old commands
>> for target `
>> clean'
>> echo "<HR>" >> r.le.setup.tmp.html
>> echo "<P><a href=index.html>Help Index</a>" >> r.le.setup.tmp.html
>> echo "</body></html>" >> r.le.setup.tmp.html
>> mkdir -p /home/smitch/src/grass-6.0.2RC3/dist.i686-pc-linux-gnu/docs/
>> html
>> mv -f r.le.setup.tmp.html /home/smitch/src/grass-6.0.2RC3/dist.i686-
>> pc-linux-gnu
>> /docs/html/r.le.setup.html
>> /usr/bin/install -c  *.png *.jpg /home/smitch/src/grass-6.0.2RC3/
>> dist.i686-pc-li
>> nux-gnu/docs/html 2> /dev/null ; true
>> make -C polytocell
>> make[1]: Entering directory `/home/smitch/src/grass-6.0.2RC3/raster/
>> r.le/r.le.se
>> tup/polytocell'
>> gcc -Wl,--export-dynamic -L/home/smitch/src/grass-6.0.2RC3/dist.i686-
>> pc-linux-gn
>> u/lib   -o /home/smitch/src/grass-6.0.2RC3/dist.i686-pc-linux-gnu/
>> bin/
>> bmif_to_ce
>> ll bmf_to_cll.o -lgrass_gis -lgrass_datetime -lz    -lm  -lz
>> bmf_to_cll.o: file not recognized: File format not recognized
>> collect2: ld returned 1 exit status
>> make[1]: *** [/home/smitch/src/grass-6.0.2RC3/dist.i686-pc-linux-gnu/
>> bin/bmif_to
>> _cell] Error 1
>> make[1]: Leaving directory `/home/smitch/src/grass-6.0.2RC3/raster/
>> r.le/r.le.set
>> up/polytocell'
>> make: *** [default] Error 2
>> [smitch at gracilis r.le.setup]$ gcc --version
>> gcc (GCC) 3.3.3 20040412 (Red Hat Linux 3.3.3-7)
> Scott,
> this are leftover files from my last test before posting
> the release candidate. The Makefile there was lacking a
> functional celan target, I have fixed that now in CVS.
> To continue, you simply need to remove the .o files in that
> directory.
> Please let us know if other problems arise with RC3.
>> All other modules compiled cleanly.
> Very good. Could you also do some tests?
> At bottom of my "GRASS workshop at OSG'05" web page
>  http://mpa.itc.it/markus/osg05/
> you find some suggestions:
>  -> A protocol to test the GRASS6/QGIS etc installations:
>     http://mpa.itc.it/markus/osg05/testing_grass6_software.txt
> Markus
