[GRASS5] GRASS 6.0.2RC3 released
Scott Mitchell smitch at mac.com
Tue Jan 10 08:51:07 EST 2006
RC4 compiled and ran fine for me under Linux FC2 and Mac OS 10.4.
The only qualification is that I couldn't test things depending on
GDAL-grass (e.g. loading a raster into GQIS), as I've managed to
break that and am having troubles compiling the plugin.  But GRASS
itself is working fine, and QGIS loaded GRASS vectors fine.  Also
tried a few "random" raster processing modules.
Cheers,
Scott
Scott Mitchell, Assistant Professor, Carleton University
Department of Geography & Environmental Studies, Loeb A209
Mailing:  Loeb B349, 1125 Colonel By Dr., Ottawa, ON K1S 5B6 Canada
1-613-520-2600 x2695 Fax: 613-520-4301 Scott_Mitchell at carleton.ca
On Jan 7, 2006, at 19:23, Scott Mitchell wrote:
> Great.  I can confirm that RC4 fixed the object file problem, and I
> got a completely clean compile.  I'll run some tests tomorrow.
> Cheers,
> Scott
> On Jan 6, 2006, at 13:24, Markus Neteler wrote:
>> On Thu, Jan 05, 2006 at 05:16:39PM -0500, Scott Mitchell wrote:
>>> Strange, in trying out 6.0.2RC3, I'm getting a compilation error on
>>> all machines that I haven't seen mention of:
>>> [smitch at gracilis r.le.setup]$ make
>>> Makefile:16: warning: overriding commands for target `clean'
>>> ../../../include/Make/Rules.make:35: warning: ignoring old commands
>>> for target `
>>> clean'
>>> echo "<HR>" >> r.le.setup.tmp.html
>>> echo "<P><a href=index.html>Help Index</a>" >> r.le.setup.tmp.html
>>> echo "</body></html>" >> r.le.setup.tmp.html
>>> mkdir -p /home/smitch/src/grass-6.0.2RC3/dist.i686-pc-linux-gnu/
>>> docs/
>>> html
>>> mv -f r.le.setup.tmp.html /home/smitch/src/grass-6.0.2RC3/dist.i686-
>>> pc-linux-gnu
>>> /docs/html/r.le.setup.html
>>> /usr/bin/install -c  *.png *.jpg /home/smitch/src/grass-6.0.2RC3/
>>> dist.i686-pc-li
>>> nux-gnu/docs/html 2> /dev/null ; true
>>> make -C polytocell
>>> make[1]: Entering directory `/home/smitch/src/grass-6.0.2RC3/raster/
>>> r.le/r.le.se
>>> tup/polytocell'
>>> gcc -Wl,--export-dynamic -L/home/smitch/src/grass-6.0.2RC3/
>>> dist.i686-
>>> pc-linux-gn
>>> u/lib   -o /home/smitch/src/grass-6.0.2RC3/dist.i686-pc-linux-gnu/
>>> bin/
>>> bmif_to_ce
>>> ll bmf_to_cll.o -lgrass_gis -lgrass_datetime -lz    -lm  -lz
>>> bmf_to_cll.o: file not recognized: File format not recognized
>>> collect2: ld returned 1 exit status
>>> make[1]: *** [/home/smitch/src/grass-6.0.2RC3/dist.i686-pc-linux-
>>> gnu/
>>> bin/bmif_to
>>> _cell] Error 1
>>> make[1]: Leaving directory `/home/smitch/src/grass-6.0.2RC3/raster/
>>> r.le/r.le.set
>>> up/polytocell'
>>> make: *** [default] Error 2
>>> [smitch at gracilis r.le.setup]$ gcc --version
>>> gcc (GCC) 3.3.3 20040412 (Red Hat Linux 3.3.3-7)
>> Scott,
>> this are leftover files from my last test before posting
>> the release candidate. The Makefile there was lacking a
>> functional celan target, I have fixed that now in CVS.
>> To continue, you simply need to remove the .o files in that
>> directory.
>> Please let us know if other problems arise with RC3.
>>> All other modules compiled cleanly.
>> Very good. Could you also do some tests?
>> At bottom of my "GRASS workshop at OSG'05" web page
>>  http://mpa.itc.it/markus/osg05/
>> you find some suggestions:
>>  -> A protocol to test the GRASS6/QGIS etc installations:
>>     http://mpa.itc.it/markus/osg05/testing_grass6_software.txt
>> Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
