[GRASS5] [bug #3973] (grass) ./configure: FORTRAN compiler not set
Glynn Clements
glynn at gclements.plus.com
Tue Jan 10 11:56:59 EST 2006
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3973
> Subject: ./configure: FORTRAN compiler not set
The check was disabled in configure.in:
revision 1.65
date: 2004/11/29 09:17:58; author: markus; state: Exp; lines: +1 -1
disabled F77 as not needed
lib/cdhc still has some Fortran files, but they aren't used.
