[GRASS5] [bug #3973] (grass) ./configure: FORTRAN compiler not set
Markus Neteler
neteler at itc.it
Tue Jan 10 12:50:23 EST 2006
On Tue, Jan 10, 2006 at 04:56:59PM +0000, Glynn Clements wrote:
> Request Tracker wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=3973
> > Subject: ./configure: FORTRAN compiler not set
> The check was disabled in configure.in:
> revision 1.65
> date: 2004/11/29 09:17:58; author: markus; state: Exp; lines: +1 -1
> disabled F77 as not needed
See
http://intevation.de/rt/webrt?serial_num=2731
You suggested to (probably) remove it:
Sun, 28 Nov 2004 05:18:33 +0000
"The configure check should probably be removed."
http://grass.itc.it/pipermail/grass5/2004-November/016200.html
> lib/cdhc still has some Fortran files, but they aren't used.
So, do we want it back? Doesn't it confuse people who do not have
Fortran installed (such as the ongoing BLAS/LAPACK confusion)?
Markus
