[GRASS5] d.vect -a|c for all types ver2
Martin Landa
landa.martin at gmail.com
Wed Jan 18 09:07:35 EST 2006
Hi Hamish,
you are right, it does not work as it should. I hope the attached
patch will solve this problem.
best regards, Martin
2006/1/18, Hamish <hamish_nospam at yahoo.com>:
> Hi,
> Just testing out the new 'd.vect -a' code in CVS.
> I found one problem that wasn't in the last version I tested:
> drawing vector points with fill color taken from GRASSRGB column works
> fine & as expected, but if you try and take off the black border with
> "color=none", nothing at all is drawn. The fill color still should be.
> draws fill areas with GRASSRGB color and symbol border in black:
> d.vect -a temp_data icon=basic/circle size=7
> doesn't draw anything:
> d.vect -a temp_data icon=basic/circle size=7 color=none
> I am trying to make a "slug trail" of points, and the border messes it
> up when the symbols overlap.
> http://bambi.otago.ac.nz/hamish/grass/profile_rgb.png
> Hamish
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060118/9c3bf682/plot1.c.bin
