[GRASS5] grass6 and R
Kirk R. Wythers kwythers at umn.edu
Wed Jan 18 10:41:41 EST 2006
On Jan 14, 2006, at 3:00 PM, Roger Bivand wrote:
>  try:
> install.packages("spgrass6", repos = rS, type="source")
> to override the default, and it should work. If you can confirm
> that it
> does, I can alter the note on the download page, and provide an
> erratum
> for the Newsletter page. If you still have difficulties, we'll need to
> work out the minimum configuration needed on OSX to install a source
> package, for example based on:
> http://cran.r-project.org/bin/macosx/RMacOSX-FAQ.html#Installation-
> of-packages
> Hope this helps,
> Roger
Roger,
Adding the type="source" work on both my powerbook and G5. I think
you can go ahead with that addendum to the newsletter.
On another note. I am looking at the R and DBMS page because I have
been using postgres for attribute management. It seems that the link
to the BioConductor web site is broken. The new url appears to be:
http://www.bioconductor.org/repository/release1.5/package/Source/
Rdbi_1.0.4.tar.gz
Therefor, shouldn't the install.package command look something like
this:
install.packages(contriburl="http://www.bioconductor.org/repository/
release1.5/package/Source/","Rdbi")?
Kirk
