[GRASS5] v.what and r.what
Sun Jan 22 04:24:33 EST 2006
twiens wrote:
> I intend to add an option to r.what to provide the same kind
> of output as v.what, but since it is desirable to have the
> commands similar should I modify v.what to take a coordinate
> pair or modify r.what to take coordinate input as two
> parameters.
Modify v.what to match r.what. r.what has been around for a while, so
you need to maintain compatibility, whereas v.what is new.
