[GRASS5] v.what and r.what
Maciek Sieczka werchowyna at epf.pl
Thu Jan 19 03:57:36 EST 2006
On śro, 2006-01-18 at 07:55 -0700, twiens wrote:
<> snip
> Also the r.what output is
> column like separated by vertical bars, where v.what has
> each attribute on its on line with the field name and its
> value.
Could you post an example?
> I intend to add an option to r.what to provide the same kind
> of output as v.what, but since it is desirable to have the
> commands similar should I modify v.what to take a coordinate
> pair or modify r.what to take coordinate input as two
> parameters. Michael prefers the separate parameters and I
> prefer it to,
Why would separate parameters be better?
Best,
Maciek
Szukasz doświadczonej firmy poligraficznej? Zależy Ci na terminowości i atrakcyjnych cenach?
Zapraszamy do nas!
http://www.foldruk.pl/
