[GRASS5] winGRASS: mingw32 and execl (g.list)
Glynn Clements
glynn at gclements.plus.com
Sun Jan 22 04:30:24 EST 2006
Roger Bivand wrote:
> Since the other commands work, the handling of path and file names may not
> be the problem. All recent Windows systems respect / as a path separator,
Use of / as a path separator has worked since DOS 2.x (the first
version of DOS which had directories). The only situation where you
have to use \ is in command-line arguments, where / is used to
indicate options (analogous to - on Unix).
