[GRASS5] Re: [GRASS-CVS] radim: grass6/lib/proj convert.c,1.18,1.19
Markus Neteler
neteler at itc.it
Sat Jan 28 01:35:40 EST 2006
should this also be fixed in 6.0.2-CVS?
Markus
On Fri, Jan 27, 2006 at 06:47:20PM +0100, grass at intevation.de wrote:
> Author: radim
> Update of /grassrepository/grass6/lib/proj
> In directory doto:/tmp/cvs-serv18826
> Modified Files:
> convert.c
> Log Message:
> use OGRSpatialReferenceH instead of pointer
> Index: convert.c
> RCS file: /grassrepository/grass6/lib/proj/convert.c,v
> retrieving revision 1.18
> retrieving revision 1.19
> diff -u -d -r1.18 -r1.19
> --- convert.c 4 Dec 2005 14:37:08 -0000 1.18
> +++ convert.c 27 Jan 2006 17:47:18 -0000 1.19
> @@ -226,12 +226,13 @@
> int GPJ_osr_to_grass(struct Cell_head *cellhd, struct Key_Value **projinfo,
> - struct Key_Value **projunits, OGRSpatialReferenceH *hSRS,
> + struct Key_Value **projunits, OGRSpatialReferenceH *phSRS,
> int interactive)
> struct Key_Value *temp_projinfo;
> char *pszProj4 = NULL, *pszRemaining;
> char *pszProj = NULL;
> + OGRSpatialReferenceH hSRS = *phSRS;
> if( hSRS == NULL )
> goto default_to_xy;
> @@ -373,6 +374,7 @@
> /* Need to make a new copy of the string so we don't mess
> * around with the memory inside the OGRSpatialReferenceH? */
> G_asprintf( &pszDatumName, pszDatumNameConst );
> GPJ_DatumNameMassage( &pszDatumName );
> grass-commit mailing list
> grass-commit at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-commit
