[GRASS5] Re: [GRASS-CVS] radim: grass6/lib/proj convert.c,1.18,1.19
Radim Blazek
radim.blazek at gmail.com
Mon Jan 30 03:37:35 EST 2006
Probably no, because older versions of QGIS
work with the buggy GPJ_osr_to_grass.
I think that it should be fixed from GRASS 6.1 (6.2.0).
Radim
On 1/28/06, Markus Neteler <neteler at itc.it> wrote:
> Hi,
> should this also be fixed in 6.0.2-CVS?
> Markus
> On Fri, Jan 27, 2006 at 06:47:20PM +0100, grass at intevation.de wrote:
> > Author: radim
> > Update of /grassrepository/grass6/lib/proj
> > In directory doto:/tmp/cvs-serv18826
> > Modified Files:
> > convert.c
> > Log Message:
> > use OGRSpatialReferenceH instead of pointer
> > Index: convert.c
> > RCS file: /grassrepository/grass6/lib/proj/convert.c,v
> > retrieving revision 1.18
> > retrieving revision 1.19
> > diff -u -d -r1.18 -r1.19
> > --- convert.c 4 Dec 2005 14:37:08 -0000 1.18
> > +++ convert.c 27 Jan 2006 17:47:18 -0000 1.19
> > @@ -226,12 +226,13 @@
> > int GPJ_osr_to_grass(struct Cell_head *cellhd, struct Key_Value **projinfo,
> > - struct Key_Value **projunits, OGRSpatialReferenceH *hSRS,
> > + struct Key_Value **projunits, OGRSpatialReferenceH *phSRS,
> > int interactive)
> > struct Key_Value *temp_projinfo;
> > char *pszProj4 = NULL, *pszRemaining;
> > char *pszProj = NULL;
> > + OGRSpatialReferenceH hSRS = *phSRS;
> > if( hSRS == NULL )
> > goto default_to_xy;
> > @@ -373,6 +374,7 @@
> > /* Need to make a new copy of the string so we don't mess
> > * around with the memory inside the OGRSpatialReferenceH? */
> > G_asprintf( &pszDatumName, pszDatumNameConst );
> > GPJ_DatumNameMassage( &pszDatumName );
> > grass-commit mailing list
> > grass-commit at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-commit
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
