[GRASS5] Re: [GRASSLIST:10033] Re: AW: Problem installing GDAL
Radim Blazek radim.blazek at gmail.com
Mon Jan 30 04:14:21 EST 2006
On 1/28/06, Huidae Cho <grass4u at gmail.com> wrote:
> Hi,
> Since G_asprintf() function is now defined as a macro on some platforms having
> asprintf(), test for G_asprintf() in GDAL configure fails.  Open the GDAL
> configure script and change all G_asprintf strings to G_version.
> Hope it helps.
> Huidae Cho
Sorry. I was noit aware of G_asprintf use in GDAL configure.
I have changed GRASS library to implement G_asprintf instead of
macro. We can reintroduce the macro when a stable version of GDAL
using a different function will become widely used.
G_version probably is not the best because it is buggy, it is
using pointers instead of pointers to pointers.
What about G_gisinit?
Radim
> On Fri, Dec 09, 2005 at 10:51:55AM +0100, Maik Trömel wrote:
> > I have forgotten to write which versions I'm running:
> > proj: 4.4.9
> > geos:  2.1.4
> > gdal: 1.3.1
> > grass: 6.0.1
> > gdal-grass: 1.3.1
> >  Georg Lösel wrote:
> > >Hello Maik,
> > >>I have installed grass-6.0.1 and now i want to run "./configure
> > >configure for GDAL ! Right?
> > Right!
> > >>--with-grass='/.../grass-6.0.1/lib/'
> > >try --with-grass=/usr/local/grass-6.0.1/
> > Same problem. Is it possible that I've got the wrong version of one package?
> > >HTH Georg
> > Greetings Maik
