[GRASS5] Re: [GRASSLIST:10037] Re: AW: Problem installing GDAL
    Soeren Gebbert
    soerengebbert at gmx.de
    Mon Jan 30 06:08:42 EST 2006
Radim Blazek schrieb:
>On 1/28/06, Huidae Cho <grass4u at gmail.com> wrote:
>>Hi,
>>Since G_asprintf() function is now defined as a macro on some platforms having
>>asprintf(), test for G_asprintf() in GDAL configure fails.  Open the GDAL
>>configure script and change all G_asprintf strings to G_version.
>>Hope it helps.
>>Huidae Cho
>Sorry. I was noit aware of G_asprintf use in GDAL configure.
>I have changed GRASS library to implement G_asprintf instead of
>macro. We can reintroduce the macro when a stable version of GDAL
>using a different function will become widely used.
>G_version probably is not the best because it is buggy, it is
>using pointers instead of pointers to pointers.
>What about G_gisinit?
>Radim
I had the same problem with gdal and gdal-grass. I
replaced G_asprintf with G_malloc in booth programms
and it worked.
But since the grass-imgaing and gdal issues, i only get segfaults
when using r.in.gdal. The segfaults appear's in a gdal method.
Greets
Soeren
>>On Fri, Dec 09, 2005 at 10:51:55AM +0100, Maik Trömel wrote:
>>>I have forgotten to write which versions I'm running:
>>>proj: 4.4.9
>>>geos:  2.1.4
>>>gdal: 1.3.1
>>>grass: 6.0.1
>>>gdal-grass: 1.3.1
>>> Georg Lösel wrote:
>>>>Hello Maik,
>>>>>I have installed grass-6.0.1 and now i want to run "./configure
>>>>configure for GDAL ! Right?
>>>Right!
>>>>>--with-grass='/.../grass-6.0.1/lib/'
>>>>try --with-grass=/usr/local/grass-6.0.1/
>>>Same problem. Is it possible that I've got the wrong version of one package?
>>>>HTH Georg
>>>Greetings Maik
