[GRASS5] Re: [GRASSLIST:10033] Re: AW: Problem installing GDAL
Huidae Cho grass4u at gmail.com
Mon Jan 30 11:03:46 EST 2006
On Mon, Jan 30, 2006 at 10:14:21AM +0100, Radim Blazek wrote:
> On 1/28/06, Huidae Cho <grass4u at gmail.com> wrote:
> > Hi,
> > Since G_asprintf() function is now defined as a macro on some platforms having
> > asprintf(), test for G_asprintf() in GDAL configure fails.  Open the GDAL
> > configure script and change all G_asprintf strings to G_version.
> > Hope it helps.
> > Huidae Cho
> Sorry. I was noit aware of G_asprintf use in GDAL configure.
> I have changed GRASS library to implement G_asprintf instead of
> macro. We can reintroduce the macro when a stable version of GDAL
> using a different function will become widely used.
> G_version probably is not the best because it is buggy, it is
> using pointers instead of pointers to pointers.
> What about G_gisinit?
I've fixed the bug in CVS.  G_gisinit also looks good to me.
Huidae Cho
> Radim
> > On Fri, Dec 09, 2005 at 10:51:55AM +0100, Maik Trömel wrote:
> > > I have forgotten to write which versions I'm running:
> > > proj: 4.4.9
> > > geos:  2.1.4
> > > gdal: 1.3.1
> > > grass: 6.0.1
> > > gdal-grass: 1.3.1
> > >  Georg Lösel wrote:
> > > >Hello Maik,
> > > >>I have installed grass-6.0.1 and now i want to run "./configure
> > > >configure for GDAL ! Right?
> > > Right!
> > > >>--with-grass='/.../grass-6.0.1/lib/'
> > > >try --with-grass=/usr/local/grass-6.0.1/
> > > Same problem. Is it possible that I've got the wrong version of one package?
> > > >HTH Georg
> > > Greetings Maik
