[GRASS-dev] [bug #4757] (grass) lib/gis/done_msg.c fails
Glynn Clements
glynn at gclements.plus.com
Sat Jul 1 14:46:30 EDT 2006
Markus Neteler wrote:
> > > this bug's URL: http://intevation.de/rt/webrt?serial_num=4757
> > > Subject: lib/gis/done_msg.c fails
> > > grass obtained from: CVS
> > > grass binary for platform: Compiled from Sources
> > > Hi,
> > > both getlogin() and G_whoami() fail in lib/gis/done_msg.c.
> > > It is not clear to me why these functions are needed at all.
> > I suspect that it's to handle the situation where you start a job in
> > the background, log out, someone else logs in, your background job
> > completes and writes the completion message to the terminal.
> > This doesn't actually work on Linux, but I can't find any
> > documentation which addresses this situation. There isn't any
> > fundamental reason why a process which has a descriptor for the
> > terminal can't continue to use the terminal after you've logged out.
> > The code in G_done_msg() checks whether the user running the process
> > (as determined by G_whoami()) is the same as the user who is listed in
> > the utmp file as being logged in on the terminal.
> > IMHO, getting rid of that check is unlikely to have any adverse
> > consequences in real use.
> not sure if I interprete your opinion correctly:
> Approval for the proposed minimization of lib/gis/done_msg.c?
Yes.
