[GRASS-dev] change permissions for mapsets
Hamish
hamish_nospam at yahoo.com
Sun Jul 2 23:38:33 EDT 2006
Otto Dassau wrote:
> I work in a project (mapset) and during my holliday another user shall
> keep on working for me. If I don't want to create an extra mapset,
> because I will be back in a couple of weeks and don't want to have
> all data and results split in 2 mapsets, I could change the owner of
> the mapset. Is this correct?
you could do that. But fetching maps from other mapsets in the same
location is very easy:
# select "map1" from the "otto" mapset: (if g.access permission is granted)
r.univar map1 at otto
# copy a map from another mapset back to your mapset for modification:
g.copy map2 at other,map2
Hamish
