[GRASS-dev] change permissions for mapsets
Sat Jul 1 15:04:52 EDT 2006
Otto Dassau wrote:
> > 1. You cannot select a mapset as the current mapset (where any new
> > maps will be created) unless you own the mapset directory; having
> > write permission isn't sufficient.
> does this mean, only one user (the owner of a mapset) can create
> new maps in 'his/her' mapset?
Yes.
> So if I want another user to have write permissions I would have to
> change the owner of the mapset directory.
Yes.
> for example:
> I work in a project (mapset) and during my holliday another user shall
> keep on working for me. If I don't want to create an extra mapset, because
> I will be back in a couple of weeks and don't want to have all data and
> results split in 2 mapsets, I could change the owner of the mapset. Is
> this correct?
Yes.
