[GRASS-dev] v.in.dxf patch
Soeren Gebbert soerengebbert at gmx.de
Sun Jul 2 15:16:00 EDT 2006
Dear devs,
i noticed a strange behaviour of v.in.dxf while implementing
some new vector tests for the grass-test-suite.
v.in.dxf was not able to import dxf files created with v.out.dxf.
No error message was printed and v.in.dxf automatically removed
the created vector?!
I am not sure if this is a bug, because i have no "real" dxf data to test
this, but i have attached a patch which adds
* a error message before deleting the corrupted vector file
* a small if check -> which allows to import files created with v.out.dxf.
I will submit this patch to CVS in the next week if this is ok for you.
Best regards
Soeren
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060702/e10747fe/v.in.dxf_soeren_patch.bin
