[GRASS-dev] v.in.dxf patch
Huidae Cho
grass4u at gmail.com
Sun Jul 2 20:35:49 EDT 2006
This is a bug and I've fixed it.
Thank you.
Huidae Cho
On Sun, Jul 02, 2006 at 09:16:00PM +0200, Soeren Gebbert wrote:
> Dear devs,
> i noticed a strange behaviour of v.in.dxf while implementing
> some new vector tests for the grass-test-suite.
> v.in.dxf was not able to import dxf files created with v.out.dxf.
> No error message was printed and v.in.dxf automatically removed
> the created vector?!
> I am not sure if this is a bug, because i have no "real" dxf data to test
> this, but i have attached a patch which adds
> * a error message before deleting the corrupted vector file
> * a small if check -> which allows to import files created with v.out.dxf.
> I will submit this patch to CVS in the next week if this is ok for you.
> Best regards
> Soeren
> Index: dxf_to_vect.c
> RCS file: /home/grass/grassrepository/grass6/vector/v.in.dxf/dxf_to_vect.c,v
> retrieving revision 1.16
> diff -u -u -r1.16 dxf_to_vect.c
> --- dxf_to_vect.c 8 Jun 2006 00:48:38 -0000 1.16
> +++ dxf_to_vect.c 2 Jul 2006 18:41:13 -0000
> @@ -81,6 +81,8 @@
> while ((code = dxf_get_code(dxf)) != 9) {
> if (code == -2) /* EOF */
> return -1;
> + if (code == 0) /* End of the header section */
> + break;
> Index: main.c
> RCS file: /home/grass/grassrepository/grass6/vector/v.in.dxf/main.c,v
> retrieving revision 1.35
> diff -u -u -r1.35 main.c
> --- main.c 12 Jun 2006 05:42:40 -0000 1.35
> +++ main.c 2 Jul 2006 18:41:13 -0000
> @@ -179,6 +179,7 @@
> else {
> + G_warning("Something strange happened! The created vector is corrupted and will be deleted.");
> fprintf(stderr, "REMOVE [%s]\n", output);
> Vect_delete(output);
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
