[GRASS-dev] Re: [bug #1140] (grass) Non-portable snprintf() used in several programs
Markus Neteler neteler at itc.it
Tue Jul 4 09:23:57 EDT 2006
Hello Paul,
On Tue, Jul 04, 2006 at 02:08:48PM +0100, Paul Kelly wrote:
> Hello Markus!
> I contend that most of those recent introductions of snprintf() probably
> don't need it. E.g. the first one (raster3d/r3.in.acii/main.c) can
> calculate the length of the string to be malloc'ed using strlen() so can
> guarantee to leave enough space. The second one (db/drivers/dbf/dbfexe.c)
> can use a fixed field width specifier for the %d format string to fix the
> length also - again predictable.
> So I will work through those and see if I can change them not to use
> snprintf(). Started it now. I feel if there's something where the length
> of the resulting string really cannot be predicted, then we should use
> G_asprintf() because it's there. It does seem to be a matter of personal
> preference and philosophy though! But I think as Glynn has said before,
> most of the places snprintf() is used the return value is not checked. So
> if an overflow was prevented, and the string was not the expected value,
> the program would just ignore it!
> So to summarise - G_snprintf() would be useful to have to easily fix
> the places that snprintf() was erroneously introduced - so you could put
> it in, but I think we should discourage its use in favour of calculating
> how long the string will be and allocating enough memory.
thanks for working on it.
I have submitted now the G_snprintf() wrapper function to
lib/gis/snprintf.c
with the discouragement included on top.
You may use it now if snprintf() cannot be avoided.
Markus
