[GRASS-dev] Re: [bug #1140] (grass) Non-portable snprintf() used in several programs
Tue Jul 4 15:50:15 EDT 2006
Paul Kelly wrote:
> I contend that most of those recent introductions of snprintf() probably
> don't need it. E.g. the first one (raster3d/r3.in.acii/main.c) can
> calculate the length of the string to be malloc'ed using strlen() so can
> guarantee to leave enough space. The second one (db/drivers/dbf/dbfexe.c)
> can use a fixed field width specifier for the %d format string to fix the
> length also - again predictable.
Field width specifiers only control the minimum width of a field (i.e.
the amount of padding or the number of leading zeroes); a field can
still be larger than the specified width.
For %d, it's reasonable to assume a 32-bit integer, which means that
it can never be more than 11 characters wide (10 digits, with a
leading minus if negative).
