[GRASS-dev] GRASS 6.1.0 release preparation
Markus Neteler
neteler at itc.it
Thu Jul 6 04:19:57 EDT 2006
Benjamin,
another, more standardized option is to use
grass.pc.in
grass.pc (generated by configure from grass.pc.in)
Markus
Benjamin Ducke wrote on 07/06/2006 09:59 AM:
> The plan is:
> Extension authors should provide a list of external dependencies
> that must be satisfied.
> GEM could then check if the GRASS installation satisfies these
> and at least issue a warning if not.
> Benjamin
> Michael Barton wrote:
>> Benjamin,
>> I don't think this would work for precompiled binaries. They may be
>> installed on a system that doesn't have some of the dependencies. For
>> example, you can compile with MySQL support and then put GRASS on a
>> system
>> without MySQL.
>> Michael
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics & Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
>>> From: Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de>
>>> Date: Wed, 05 Jul 2006 10:20:56 +0200
>>> Cc: <grass-dev at grass.itc.it>
>>> Subject: Re: [GRASS-dev] GRASS 6.1.0 release preparation
>>> I have one request concerning the GRASS configure script:
>>> would it be possible for configure to write a small one-line
>>> ASCII file into GISBASE/etc after a successful configuration,
>>> which contains all the options that the user passed to the
>>> configure script?
>>> Having such a file in a standard location would make it
>>> much easier to compile external modules with exactly the
>>> same external dependencies as the GRASS system installation.
>>> Best,
>>> Benjamin
>>> Markus Neteler wrote:
>>>> On Tue, Jul 04, 2006 at 12:26:16AM -0400, Helena Mitasova wrote:
>>>>> Some modules have problems running on 64bit (maybe that is also
>>>>> #4725?
>>>> The nviz volume bug was recently introduces, I think. As far
>>>> as I remember it worked some time ago on 64bit.
>>>> https://intevation.de/rt/webrt?serial_num=4725
>>>> " I followed "mode" into lib/ogsf/GVL2.c GVL_slice_get_drawmode()
>>>> and then *gvl to gvl_get_vol() in lib/ogsf/gvl.c, but then I get
>>>> lost.
>>>>> but it is for sure #4546
>>>> https://intevation.de/rt/webrt?serial_num=4546
>>>> r.sim.water crashes in simlib/input.c line 403, function grad_check():
>>>> if (cchez[k][l] != 0.) {
>>>> with k=700 and l=0
>>>> Not sure why.
>>>>> and supposedly also r.sun - probably due to uninitialized
>>>>> variables).
>>>> Right, It crashes in INPUT () at main.c:656
>>>> if (z[i][j] == UNDEFZ || o[i][j] == UNDEFZ || s[i][j] ==
>>>> UNDEFZ)
>>>> Here a Spearfish test script:
>>>> ELEV=elevation.dem
>>>> TMP=$$
>>>> SLOPE=$TMP.slope
>>>> ASP=$TMP.aspect
>>>> r.slope.aspect elevation.dem as=$TMP.aspect sl=$TMP.slope --o
>>>> r.mapcalc global_shadow.rad=0
>>>> DAY=055
>>>> r.sun -s elevin=elevation.dem aspin=$TMP.aspect slopein=$TMP.slope
>>>> day=$DAY \
>>>> beam_rad=bs_rad.$DAY diff_rad=ds_rad.$DAY refl_rad=rs_rad.$DAY
>>>>> I don't think that this should stop the release.
>>>> I would appreciate if those two bugs would be fixed, but we
>>>> can backport the fixes later.
>>>>> Also I believe that we should thoroughly test gis.m before release -
>>>>> we were getting all kinds of error messages but I think that it all
>>>>> has been fixed by now.
>>>> Yes, gis.m should get a consolidation cycle now.
>>>> Markus
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> http://grass.itc.it/mailman/listinfo/grass-dev
>>> Benjamin Ducke, M.A.
>>> Archäoinformatik
>>> (Archaeoinformation Science)
>>> Institut für Ur- und Frühgeschichte
>>> (Inst. of Prehistoric and Historic Archaeology)
>>> Christian-Albrechts-Universität zu Kiel
>>> Johanna-Mestorf-Straße 2-6
>>> D 24098 Kiel
>>> Germany
>>> Tel.: ++49 (0)431 880-3378 / -3379
>>> Fax : ++49 (0)431 880-7300
>>> www.uni-kiel.de/ufg
