[GRASS-dev] Re: [GRASS-user] v.in.ascii error message
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Thu Jul 13 06:09:12 EDT 2006
you need to delimit records with | not lines
and then have one record per line like this:
W115|58|2.4
N36|27|20.9
Also, I am not sure if W115 or N36 is a correct
way of specifying the coordinates?
Unfortunately, v.in.ascii almost always give that
error message, which is usually not to helpful.
Benjamin
gary wrote:
> I find this error message from v.in.ascii a bit cryptic.
> grass command:
> v.in.ascii input=/usr/localsrc/utm/PERMANENT/site.dat output=sites5
> format=point fs=| skip=0 x=1 y=2 z=0 cat=0
> error message:
> Maximum input row length: 24
> Maximum number of columns: 2
> Minimum number of columns: 0
> GRASS_INFO_ERROR(15897,1): x column number > minimum last column number
> GRASS_INFO_ERROR(15897,1): (incorrect field separator?)
> The file site. dat is one line as follows
> W115 58 2.4|N36 27 20.9
> The default separator is "pipe", so I'm sure the delimiter is fine. Any
> idea what I'm doing wrong here?
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
