[GRASS-dev] Re: [GRASS-user] v.in.ascii error message
Markus Neteler
neteler at itc.it
Fri Jul 14 06:37:01 EDT 2006
On Thu, Jul 13, 2006 at 12:09:12PM +0200, Benjamin Ducke wrote:
> you need to delimit records with | not lines
> and then have one record per line like this:
> W115|58|2.4
> N36|27|20.9
> Also, I am not sure if W115 or N36 is a correct
> way of specifying the coordinates?
I guess that it should be
115:58:2.4W|36:27:20.9N
instead of
W115 58 2.4|N36 27 20.9
Markus
> Unfortunately, v.in.ascii almost always give that
> error message, which is usually not to helpful.
> Benjamin
> gary wrote:
> >I find this error message from v.in.ascii a bit cryptic.
> >grass command:
> >v.in.ascii input=/usr/localsrc/utm/PERMANENT/site.dat output=sites5
> >format=point fs=| skip=0 x=1 y=2 z=0 cat=0
> >error message:
> >Maximum input row length: 24
> >Maximum number of columns: 2
> >Minimum number of columns: 0
> >GRASS_INFO_ERROR(15897,1): x column number > minimum last column number
> >GRASS_INFO_ERROR(15897,1): (incorrect field separator?)
> >The file site. dat is one line as follows
> >The default separator is "pipe", so I'm sure the delimiter is fine. Any
> >idea what I'm doing wrong here?
> >_______________________________________________
> >grassuser mailing list
> >grassuser at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grassuser
> Benjamin Ducke, M.A.
> Archäoinformatik
> (Archaeoinformation Science)
> Institut für Ur- und Frühgeschichte
> (Inst. of Prehistoric and Historic Archaeology)
> Christian-Albrechts-Universität zu Kiel
> Johanna-Mestorf-Straße 2-6
> D 24098 Kiel
> Germany
> Tel.: ++49 (0)431 880-3378 / -3379
> Fax : ++49 (0)431 880-7300
> www.uni-kiel.de/ufg
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
