[GRASS-dev] New raster-to-raster3d conversion module
Sat Jul 15 07:44:37 EDT 2006
Soeren Gebbert  wrote:
> With r.elev.to.rast3 you can put raster map values from a specific map
> (input)  in a specific elevation layer within a g3d volume, based on a
> 2D elevation map (elev). Every 3D cell of the volume that intersect
> with the elevation map will be set to the cell value of the input map.
> If the hight value of the elevation map is exactly located at the
> border between two 3D cells, both cells will get the input map value.
> This works perfectly for putting geological strata into g3d volumes. I
> need this for modelling a 3D aquifer.
I'm not sure if I mentioned this before, if I did please ignore the
duplicate.
consider renaming the module "r.to.rast3.elev" (or similar) so like
modules are grouped together both in the help pages and logically.
thanks,
Hamish
