[GRASS-dev] New raster-to-raster3d conversion module
Helena Mitasova hmitaso at unity.ncsu.edu
Sat Jul 15 11:08:22 EDT 2006
On Jul 15, 2006, at 7:44 AM, Hamish wrote:
> Soeren Gebbert  wrote:
>> With r.elev.to.rast3 you can put raster map values from a specific
>> map
>> (input)  in a specific elevation layer within a g3d volume, based
>> on a
>> 2D elevation map (elev). Every 3D cell of the volume that intersect
>> with the elevation map will be set to the cell value of the input
>> map.
>> If the hight value of the elevation map is exactly located at the
>> border between two 3D cells, both cells will get the input map value.
>> This works perfectly for putting geological strata into g3d
>> volumes. I
>> need this for modelling a 3D aquifer.
> I'm not sure if I mentioned this before, if I did please ignore the
> duplicate.
> consider renaming the module "r.to.rast3.elev" (or similar) so like
> modules are grouped together both in the help pages and logically.
given my previou notes about the 2 dots, it looks like r.to.rast3elev
would be a good choice,
Helena
> thanks,
> Hamish
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
