[GRASS-dev] New raster-to-raster3d conversion module
Sat Jul 15 19:56:06 EDT 2006
Helena Mitasova wrote:
> >> With r.elev.to.rast3 you can put raster map values from a specific
> >> map
> >> (input)  in a specific elevation layer within a g3d volume, based
> >> on a
> >> 2D elevation map (elev). Every 3D cell of the volume that intersect
> >> with the elevation map will be set to the cell value of the input
> >> map.
> >> If the hight value of the elevation map is exactly located at the
> >> border between two 3D cells, both cells will get the input map value.
> >> This works perfectly for putting geological strata into g3d
> >> volumes. I
> >> need this for modelling a 3D aquifer.
> > I'm not sure if I mentioned this before, if I did please ignore the
> > duplicate.
> > consider renaming the module "r.to.rast3.elev" (or similar) so like
> > modules are grouped together both in the help pages and logically.
> given my previou notes about the 2 dots, it looks like r.to.rast3elev
> would be a good choice,
Is there any particuarl reason for imposing a "two dots" restriction?
