[GRASS-dev] Re: [GRASS-CVS] michael: grass6/lib/init gis_set.tcl,
1.24, 1.25
Markus Neteler
neteler at itc.it
Mon Jul 17 13:35:56 EDT 2006
a few questions:
On Mon, Jul 17, 2006 at 07:28:42PM +0200, grass at intevation.de wrote:
> Author: michael
> Update of /grassrepository/grass6/lib/init
> In directory doto:/tmp/cvs-serv30054
> Modified Files:
> gis_set.tcl
> Log Message:
> update exec and eval exec statements to properly parse arguments
> Index: gis_set.tcl
> RCS file: /grassrepository/grass6/lib/init/gis_set.tcl,v
> retrieving revision 1.24
> retrieving revision 1.25
> diff -u -d -r1.24 -r1.25
> --- gis_set.tcl 24 Jun 2006 19:33:59 -0000 1.24
> +++ gis_set.tcl 17 Jul 2006 17:28:40 -0000 1.25
> @@ -312,10 +312,10 @@
> pack $introtitle -side top
> .frame0.intro.msg tag configure all -justify center
> - .frame0.intro.msg insert end [G_msg "Welcome to GRASS GIS Version $GRASSVERSION\n"]
> + .frame0.intro.msg insert end [G_msg "Welcome to GRASS GIS version $GRASSVERSION\n"]
> .frame0.intro.msg insert end [G_msg "The world's leading open source GIS\n\n"]
> - .frame0.intro.msg insert end [G_msg "Select an existing project location and mapset\n"]
> - .frame0.intro.msg insert end [G_msg "or define a new project location\n"]
> + .frame0.intro.msg insert end [G_msg "Select an existing projection location and GIS mapset\n"]
... what does "existing projection location" mean?
I only know "existing project location". The change adds confusion in my opinion.
If projected is meant, it is not right since latlong (usually) and xy (always) are
unprojected.
> + .frame0.intro.msg insert end [G_msg "or define a new projection location\n"]
...also here.
> .frame0.intro.msg tag add all 1.0 end
> .frame0.intro.msg configure -state disabled
> @@ -338,7 +338,7 @@
> label .frame0.frameDB.left.label \
> -anchor {n} \
> -justify right \
> - -text [G_msg "Path to location: \n(GRASS Database)"]
> + -text [G_msg "Path to location : "]
"GRASS Database" is a widely used term in the GRASS literature,
but sure if it should be removed.
> entry .frame0.frameDB.mid.entry \
> -relief {sunken} \
> @@ -408,7 +408,7 @@
> label .frame0.frameMS.label \
> -anchor {w} \
> - -text [G_msg "Accessible Mapsets"]
> + -text [G_msg "(Accessible) GIS Mapsets"]
... this re-reverted the last fix...
The () do not add information in my opionion.
> listbox .frame0.frameMS.listbox \
> -relief {sunken} \
> @@ -460,7 +460,7 @@
> label .frame0.frameNMS.first.label \
> -anchor {n} \
> - -text [G_msg "Create new mapset\nin selected location"]
> + -text [G_msg "Create new GIS mapset\nin currrent location"]
I am also not sure of that. In the beginning nothing is selected,
so there is no currrent location.
> entry .frame0.frameNMS.second.entry \
> -relief {sunken} \
> @@ -495,7 +495,7 @@
> label .frame0.frameNMS.fourth.label \
> -anchor {n} \
> - -text [G_msg "\nDefine new location by:"]
> + -text [G_msg "Define new projection location"]
... again confusing (for me).
> button .frame0.frameNMS.fifth.button \
It seems that this needs to be discussed again: at least I
would like to better understand most of the changes.
thanks
Markus
