[GRASS-dev] Re: [GRASS-CVS] michael: grass6/lib/init
gis_set.tcl, 1.24, 1.25
Michael Barton
michael.barton at asu.edu
Mon Jul 17 16:21:05 EDT 2006
Markus,
I'm happy to see suggestions. Here is my rational for wording changes. Maybe
there can be better wording than my quick fix.
I'm trying to think of a user who knows something about GIS and is opening
GRASS for the first time. Before she or he can do anything--even start the
program--they have to choose a "database", "location", and "mapset".
But what is a database? Of course everyone knows that a database is an
attribute table or related set of attribute tables defined in a data
dictionary. Except that's not what a GRASS database is. It is simply the
directory/folder where "locations" are stored.
But what is a location? Of course that is a place, maybe where your study
area is located. But how do you select that? Except in GRASS, a "location"
is really a folder with definitions of the projection (including 'geographic
projections' like latlon), coordinate system, and optionally the extents
defining a particular part of the world. More people would probably
understand what we mean if we ask them to choose the projection/coordinate
system than to choose a "location".
Then you have to select a "mapset". But what is a mapset. In GRASS, that's
where your GIS files are stored--which is what this hypothetical new user
has really wanted to get at all along.
Every time I try to explain how to start GRASS, I have to explain what a
"database", "location", and "mapset" is before the person can even get
started working with the program. Any GIS will have some jargon that a
person will have to get through (e.g., 'theme' instead of layer). But it
would be nice to not have to hit someone with GRASS-specific jargon before
they even get the program opened. Of course you can press the help button,
but many people would just like to start the program before doing anything
else.
So I was trying to build in some translations of GRASS jargon to help
someone get started. I dropped "GIS Database" because it's not used much.
But location and mapset are used a lot. Of course this made for some awkward
phraseology, as you noticed. I really did mean "projection location"
instead of project location.
Maybe "Select an existing 'location' (projection/coordinate system) and GIS
Mapset..."???
GIS Mapset doesn't sound too awkward to me. But maybe to others?
Suggestions?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Markus Neteler <neteler at itc.it>
> Date: Mon, 17 Jul 2006 19:35:56 +0200
> To: <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] Re: [GRASS-CVS] michael: grass6/lib/init gis_set.tcl,
> 1.24, 1.25
> Hi,
> a few questions:
> On Mon, Jul 17, 2006 at 07:28:42PM +0200, grass at intevation.de wrote:
>> Author: michael
>> Update of /grassrepository/grass6/lib/init
>> In directory doto:/tmp/cvs-serv30054
>> Modified Files:
>> gis_set.tcl
>> Log Message:
>> update exec and eval exec statements to properly parse arguments
>> Index: gis_set.tcl
>> RCS file: /grassrepository/grass6/lib/init/gis_set.tcl,v
>> retrieving revision 1.24
>> retrieving revision 1.25
>> diff -u -d -r1.24 -r1.25
>> --- gis_set.tcl 24 Jun 2006 19:33:59 -0000 1.24
>> +++ gis_set.tcl 17 Jul 2006 17:28:40 -0000 1.25
>> @@ -312,10 +312,10 @@
>> pack $introtitle -side top
>> .frame0.intro.msg tag configure all -justify center
>> - .frame0.intro.msg insert end [G_msg "Welcome to GRASS GIS Version
>> $GRASSVERSION\n"]
>> + .frame0.intro.msg insert end [G_msg "Welcome to GRASS GIS version
>> $GRASSVERSION\n"]
>> .frame0.intro.msg insert end [G_msg "The world's leading open source
>> GIS\n\n"]
>> - .frame0.intro.msg insert end [G_msg "Select an existing project location
>> and mapset\n"]
>> - .frame0.intro.msg insert end [G_msg "or define a new project
>> location\n"]
>> + .frame0.intro.msg insert end [G_msg "Select an existing projection
>> location and GIS mapset\n"]
> ... what does "existing projection location" mean?
> I only know "existing project location". The change adds confusion in my
> opinion.
> If projected is meant, it is not right since latlong (usually) and xy (always)
> are
> unprojected.
>> + .frame0.intro.msg insert end [G_msg "or define a new projection
>> location\n"]
> ...also here.
>> .frame0.intro.msg tag add all 1.0 end
>> .frame0.intro.msg configure -state disabled
>> @@ -338,7 +338,7 @@
>> label .frame0.frameDB.left.label \
>> -anchor {n} \
>> -justify right \
>> - -text [G_msg "Path to location: \n(GRASS Database)"]
>> + -text [G_msg "Path to location : "]
> "GRASS Database" is a widely used term in the GRASS literature,
> but sure if it should be removed.
>> entry .frame0.frameDB.mid.entry \
>> -relief {sunken} \
>> @@ -408,7 +408,7 @@
>> label .frame0.frameMS.label \
>> -anchor {w} \
>> - -text [G_msg "Accessible Mapsets"]
>> + -text [G_msg "(Accessible) GIS Mapsets"]
> ... this re-reverted the last fix...
> The () do not add information in my opionion.
>> listbox .frame0.frameMS.listbox \
>> -relief {sunken} \
>> @@ -460,7 +460,7 @@
>> label .frame0.frameNMS.first.label \
>> -anchor {n} \
>> - -text [G_msg "Create new mapset\nin selected location"]
>> + -text [G_msg "Create new GIS mapset\nin currrent location"]
> I am also not sure of that. In the beginning nothing is selected,
> so there is no currrent location.
>> entry .frame0.frameNMS.second.entry \
>> -relief {sunken} \
>> @@ -495,7 +495,7 @@
>> label .frame0.frameNMS.fourth.label \
>> -anchor {n} \
>> - -text [G_msg "\nDefine new location by:"]
>> + -text [G_msg "Define new projection location"]
> ... again confusing (for me).
>> button .frame0.frameNMS.fifth.button \
> It seems that this needs to be discussed again: at least I
> would like to better understand most of the changes.
> thanks
> Markus
