[GRASS-dev] GDAL's GRASS plugin
Hamish
hamish_nospam at yahoo.com
Tue Jul 18 23:46:06 EDT 2006
just compiled latest GDAL from CVS + GRASS plugin 1.3.1.2.
two issues:
1) probably just README needs updating or I need to read it better?
cd gdal/frmts/grass/pkg
./configure ...
make: *** No rule to make target `grass57dataset.o', needed by `gdal_GRASS.so'. Stop.
(I assume this needs re./configure --with-grass= after GRASS is built)
[build GRASS with new GDAL libs]
2) gdal installs a broken & unwanted symlink:
downloaded GRASS plugin 1.3.1.2,
./configure
make
[ok]
# make install
install -d /usr/local/lib/gdalplugins
install: cannot create directory `/usr/local/lib/gdalplugins': File exists
make: *** [install] Error 1
# ls /usr/local/lib/gdalplugins -l
lrwxrwxrwx 1 root staff 20 2005-10-24 16:17 /usr/local/lib/gdalplugins -> /usr/lib/gdalplugins
(/usr/lib/gdalplugins doesn't exist)
if I do:
# rm /usr/local/lib/gdalplugins
# mkdir /usr/local/lib/gdalplugins
then
# make install
it works,
$ gdalinfo --formats | grep GRASS
GRASS (ro): GRASS Database Rasters (5.7+)
$ ogrinfo --formats | grep GRASS
-> "GRASS" (readonly)
Hamish
