[GRASS-dev] GDAL's GRASS plugin
Markus Neteler neteler at itc.it
Wed Jul 19 05:21:45 EDT 2006
On Wed, Jul 19, 2006 at 03:46:06PM +1200, Hamish wrote:
> Hi,
> just compiled latest GDAL from CVS + GRASS plugin 1.3.1.2.
> two issues:
> 1) probably just README needs updating or I need to read it better?
> cd gdal/frmts/grass/pkg
> ./configure ...
> make: *** No rule to make target `grass57dataset.o', needed by `gdal_GRASS.so'.  Stop.
> (I assume this needs re./configure --with-grass= after GRASS is built)
> [build GRASS with new GDAL libs]
you have to link these files from ../ into pkg/.
See
 http://mpa.itc.it/markus/useful/conf_install_gdal_ogr_grass_plugin.sh
for a convenient script to compile/install - also the OGR plugin
in the same moment.
Personally, I no longer use the plugin extra package but
compile it directly from the standard GDAL code using my
script. That makes things even easier...
cheers
 Markus
