[GRASS-dev] Re: [bug #4877] (grass) d.grid -g, ps.map: incorrect
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Jul 19 07:16:39 EDT 2006
On Wed, 19 Jul 2006, Hamish wrote:
>>> this bug's URL: http://intevation.de/rt/webrt?serial_num=4877
>>> "d.grid -g" and ps.map's geogrid command are not calculating the
>>> correct grid lines for me. (lines are drawn 90m to the north)
>>> Perhaps it is only doing the projection, and not the datum transform
>> Looking at the code, this seems quite possible. I have applied a patch
>> in CVS - can you test? If it's working now, I expect we should be
>> able to apply a similar patch to ps.map.
> umm, now it is twice as bad. the 'd.grid -g' line is now drawn 180m
> north of the expected location.
For me (I've tried with a test NZMG/nzgd49 location) before the patch the
lines were about 90m *south* of where they'd be expected to be from the
d.where -l output, and after the patch they agree :/ d.grid is supposed to
show lines of latitude&longtiude on the current ellipsoid, not WGS84,
right?
> I take it that in this case the LL datum was the one missing?
Yes the way it was being done was ll was set as the projection and the
ellipsoid parameters were copied over to the new parameters, but not the
datum. I've double-checked and am fairly confident that particular problem
is fixed now, but perhaps there was something else in the code that
compensated for this bug and so something else needs changed? I'm not sure
where to look.
Paul
