[GRASS-dev] gis.m error for i.points (guarantee_xmon exec as string not list?)
Michael Barton michael.barton at asu.edu
Fri Jul 21 15:05:01 EDT 2006
OK. Done. Also had to do it for spawn and run procedures in the
runandoutput.tcl script.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Fri, 21 Jul 2006 12:55:30 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Hamish <hamish_nospam at yahoo.com>, grass5 <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] gis.m error for i.points (guarantee_xmon exec as
> string not list?)
> Michael Barton wrote:
>> This was difficult to track down, but I got it. Glynn updated grass-run.sh
>> by adding "" around an expression parser and I removed 'eval' from an
>> expression parser (term procedure) for modules requiring an xterm in
>> runandoutput.tcl.
>> Doing one or the other of these was good. Doing both was a gotcha. Since the
>> term procedure is much more limited in effects (and I pretty much can tell
>> what is is affecting, I reverted term back to using eval. It all seems to
>> work OK now.
> However, this:
> eval exec -- xterm -name xterm-grass -e $env(GISBASE)/etc/grass-run.sh $cmd
> $args &
> should be:
> eval [list exec -- xterm -name xterm-grass -e $env(GISBASE)/etc/grass-run.sh
> $cmd] $args &
> The difference is that the latter will work correctly if there are
> spaces in either $env(GISBASE) or $cmd, while the former won't.
> The "eval" function treats all of its arguments as lists. If any of
> them aren't lists and could contain spaces, they must be turned into
> lists using the "list" function.
> On Windows, it should be possible for GRASS (as well as any commands
> which it uses and any files which it reads) to reside in either the
> "Program Files" directory or the user's "My Documents" directory, both
> of which may (and often will) contain spaces.
