[GRASS-dev] RE: [bug #4604] (grass) tcl/tk GUI: v.digit can't
create new vect or in GUI mode
Patton, Eric
epatton at nrcan.gc.ca
Mon Jul 24 10:01:23 EDT 2006
Confirmed; some caveats below.
For starters, v.digit from the CLI fails to automatically open an X-monitor;
whether this is intentional or not, it's inconsistent with the v.digit GUI
version, as that one opens x0 automatically.
# v.digit -n CLI
d.mon x0; v.digit -n map=Bugtest1
New empty map created.
# v.digit CLI (no -n flag)
d.mon x0 ; v.digit map=Opilio_ROV_Stations
using default visual which is TrueColor
ncolors: 16777216
Graphics driver [x0] started
Segmentation fault
This is important - if I try to query the vector Opilio_ROV_Stations from
the gis.m query tool, topology seems to be destroyed!
$ v.what -a map=Opilio_ROV_Stations east_north=647925.576373,5169619.14795
distance=16.2926107986 (copied from Output screen of gis.m)
(From Output screen): Opilio_ROV_Stations: You must build topology on vector
file
Ok, let's build some topology...
v.build Opilio_ROV_Stations
Building topology ...
18 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 12
Number of primitives: 18
Number of points : 12
Number of lines : 6
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
Now, if I try to edit this vector again with the CLI command
ncolors: 16777216
Segmentation fault
Similarly, topology is again destroyed as I can't query this vector until I
rebuild topology.
Moving on to the GUI version of v.digit.....
Running the command
v.digit map=Bugtest2 'bgcmd=d.rast -o
map=CheticampAll_Aug2005_10m.shade.comb' displays my background map in x0,
but no v.digit toolbar opens! The corresponding output from gis.m:
GRASS_INFO_MESSAGE(9662,1): New empty map created.
Application initialization failed: "-n" option requires an additional
argument
Error in startup script: couldn't read file "map=Bugtest2": no such file or
directory
I thought -n was supposed to take care of creating the new vector for me.
What additional argument is it talking about?
Now let's try editing an existing vector through the GUI:
v.digit map=Disposal_Sites
x0 opens, but that's it.
~ Eric.
-----Original Message-----
To: Patton, Eric
Cc: Michael.Barton at asu.edu
Sent: 7/23/2006 4:33 PM
Subject: [bug #4604] (grass) tcl/tk GUI: v.digit can't create new vector in
GUI mode
This bug is still valid in current CVS.
Maciek
-------------------------------------------- Managed by Request Tracker
