[GRASS-dev] Re: [bug #4604] (grass) tcl/tk GUI: v.digit can't
 create new vect or in GUI mode
    Michael Barton
    michael.barton at asu.edu
    Mon Jul 24 11:20:22 EDT 2006
Eric,
This is kind of a backhanded compliment I guess. From the command line,
GRASS has always had fairly primitive display control ability. NOTHING will
automatically open a display monitor of any kind.
Radim added the ability to  automatically open an x11 display monitor when
d.rast or d.vect was run to the Display Manager in GRASS 5 and 6. I added it
to the v.digit button in the old GIS Manager for GRASS 6 and someone else
added automatic background display.
These conveniences are all in the TclTk code that creates the GIS Manager.
>From the command line, you do all this manually...
D.mon start=x0
V.digit [vector map] bk=[background commands]
Etc.
Displaying things in the TclTk canvas, with display controls is completely
done within TclTk code, using display output to PPM files. This is where
things get problematic with v.digit, which only displays to an x11 monitor.
So this is NOT a bug. It is the way that the GRASS CLI is supposed to work.
You can make it a wish, however.
Cheers
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: "Patton, Eric" <epatton at nrcan.gc.ca>
> Date: Mon, 24 Jul 2006 11:01:23 -0300
> To: 'Maciek Sieczka via RT ' <grass-bugs at intevation.de>,
> "'grass-dev at grass.itc.it'" <grass-dev at grass.itc.it>
> Cc: "'Michael.Barton at asu.edu '" <Michael.Barton at asu.edu>
> Subject: RE: [bug #4604] (grass) tcl/tk GUI: v.digit can't create new vect or
> in GUI mode
> Confirmed; some caveats below.
> For starters, v.digit from the CLI fails to automatically open an X-monitor;
> whether this is intentional or not, it's inconsistent with the v.digit GUI
> version, as that one opens x0 automatically.
> #  v.digit -n CLI
> d.mon x0; v.digit -n map=Bugtest1
> New empty map created.
> #  v.digit CLI (no -n flag)
> d.mon x0 ; v.digit map=Opilio_ROV_Stations
> using default visual which is TrueColor
> ncolors: 16777216
> Graphics driver [x0] started
> Segmentation fault
> This is important - if I try to query the vector Opilio_ROV_Stations from
> the gis.m query tool,  topology seems to be destroyed!
> $ v.what -a map=Opilio_ROV_Stations east_north=647925.576373,5169619.14795
> distance=16.2926107986 (copied from Output screen of gis.m)
> (From Output screen): Opilio_ROV_Stations: You must build topology on vector
> file
> Ok, let's build some topology...
> v.build Opilio_ROV_Stations
> Building topology ...
> 18 primitives registered
> Building areas:  100%
> 0 areas built
> 0 isles built
> Attaching islands:
> Attaching centroids:  100%
> Topology was built.
> Number of nodes     :   12
> Number of primitives:   18
> Number of points    :   12
> Number of lines     :   6
> Number of boundaries:   0
> Number of centroids :   0
> Number of areas     :   0
> Number of isles     :   0
> Now, if I try to edit this vector again with the CLI command
> ncolors: 16777216
> Segmentation fault
> Similarly, topology is again destroyed as I can't query this vector until I
> rebuild topology.
> Moving on to the GUI version of v.digit.....
> Running the command
> v.digit map=Bugtest2 'bgcmd=d.rast -o
> map=CheticampAll_Aug2005_10m.shade.comb' displays my background map in x0,
> but no v.digit toolbar opens! The corresponding output from gis.m:
> GRASS_INFO_MESSAGE(9662,1): New empty map created.
> Application initialization failed: "-n" option requires an additional
> argument
> Error in startup script: couldn't read file "map=Bugtest2": no such file or
> directory
> I thought -n was supposed to take care of creating the new vector for me.
> What additional argument is it talking about?
> Now let's try editing an existing vector through the GUI:
> v.digit map=Disposal_Sites
> x0 opens, but that's it.
> ~ Eric.
> -----Original Message-----
> From: Maciek Sieczka via RT
> To: Patton, Eric
> Cc: Michael.Barton at asu.edu
> Sent: 7/23/2006 4:33 PM
> Subject: [bug #4604] (grass) tcl/tk GUI: v.digit can't create new vector in
> GUI mode
> This bug is still valid in current CVS.
> Maciek
> -------------------------------------------- Managed by Request Tracker
