[GRASS-dev] GRASS OSGEO Project Steering Committee (+1 for PSC)
Sampson, David
dsampson at NRCan.gc.ca
Tue Jul 25 15:57:33 EDT 2006
>From my point of view the main issues with GRASS for incubation into
OSGeo are the legal review of code (hard because there is so much code
accumulated over such a long period of time), and establishing a
functioning PSC. The PSC shouldn't be terribly hard since GRASS already
has had a very consensus oriented decision making approach. It's just
that the decision making approach so far is so informal as to defy
knowing if a decision has been made or not!
It sounds like a PSC should not be hard to follow through with since
GRASS already sounds on track. I'm for helping out with the PSC
+1
Whos next?
Cheers
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com] On Behalf Of Frank
Warmerdam
Sent: July 25, 2006 15:27
To: Sampson, David
Cc: grassuser at grass.itc.it; grass-dev at grass.itc.it
Subject: Re: [GRASS-user] RE: [GRASS-dev] Re: [OTT_OSGEO] GRASS OSGEO
Steering Committee
Sampson, David wrote:
> Just some thoughts
> o Core OSGeo rules (ie. not improperly incorporating others code
into
> the code base) need to be followed.
> Is this not already a given?...
Dave,
Obviously, it is the normal practice, but going forward we may need to
be more explicit and careful about what is acceptable to contribute and
what is not. I know there were a number of items I played a bit fast
and loose with in GDAL that I'm being more careful as GDAL becomes a
GDAL project.
> o The process needs to be open to additional contributors in some
> fashion.
> How is this different than the current process?
This isn't a problem for the GRASS project which has certainly been
quite open to additional contributors for as long as I have had any
association. Keep in mind the various items I pointed out are general
requirements of OSGeo. Just because I mention them doesn't mean I think
GRASS has a problem with them.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGF,
http://osgeo.org
