[GRASS-dev] [bug #4904] (grass) g.setproj: fails to modify projection info in XY location - inconsistent with g.proj
Request Tracker grass-bugs at intevation.de
Wed Jul 26 09:19:00 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4904
Subject: g.setproj: fails to modify projection info in XY location - inconsistent with g.proj
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 2006.07.24
g.setproj when called in an XY location says:
XY-location cannot be projected.
Wrong. It should allow to set/modify projection no matter what - like g.proj does.
Maciek
-------------------------------------------- Managed by Request Tracker
