[GRASS-dev] [bug #4905] (grass) gis.m: d.text.freetype does not
allow spaces in text
Request Tracker
grass-bugs at intevation.de
Wed Jul 26 11:26:07 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4905
Subject: gis.m: d.text.freetype does not allow spaces in text
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: cvs_head_20060724
As the postscript text layers do not survive saving the map display to a graphics file, I am trying to use d.text.freetype as a command.
This works perfectly until the text I want to display contains spaces. When I use the following command line:
d.text.freetype -n -b text="Population totale" east_north=2,95 size=3 col=black path=/usr/share/fonts/truetype/ttf-bitstream-vera/Vera.ttf
I get:
Sorry <totale"> is not a valid option
I have tried with single quotes and brackets, but I get the same error.
Moritz
-------------------------------------------- Managed by Request Tracker
