[GRASS-dev] [bug #4905] (grass) gis.m: d.text.freetype does not
allow spaces in text
Glynn Clements
glynn at gclements.plus.com
Wed Jul 26 13:22:50 EDT 2006
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4905
> Subject: gis.m: d.text.freetype does not allow spaces in text
> As the postscript text layers do not survive saving the map display
> to a graphics file, I am trying to use d.text.freetype as a command.
> This works perfectly until the text I want to display contains
> spaces. When I use the following command line:
> d.text.freetype -n -b text="Population totale" east_north=2,95 size=3 col=black path=/usr/share/fonts/truetype/ttf-bitstream-vera/Vera.ttf
> I get:
> Sorry <totale"> is not a valid option
> I have tried with single quotes and brackets, but I get the same error.
Using braces works, i.e.
d.text.freetype -n -b {text=Population totale} ...
There doesn't appear to actually be a space, but the same problem
occurs when running d.text.freetype from the command line, i.e. it's a
problem with d.text.freetype.
