[GRASS-dev] gis.m: cannot get profile from profile tool
Moritz Lennert mlennert at club.worldonline.be
Thu Jul 27 02:33:11 EDT 2006
Michael Barton wrote:
> Hi Moritz,
> Did you select a raster to profile?
Yes, as you can see in the screenshot, it says in the bottom left:
"Profile for srtm_be".
> Third button from the left on the
> profiler toolbar.
> Rather like d.profile, the profiler differentiates between
> a map you use as a background to the profiling line (what is shown in the
> map display) and the map that you actually use to compute profile values.
I understand that, but I still don't get a profile. Actually, I
sometimes do not even get the straight blue line you see in the
screenshot (http://moritz.homelinux.org/grass/gism_profile.png), just an
empty graph.
The min and max of the heights on the y axis seem correct, though.
Moritz
