[GRASS-dev] Compilation errors in GRASS for Mac
Agustin Diez Castillo adiez at uv.es
Thu Jul 27 19:35:14 EDT 2006
I got these errors with Kyngesburye's flags.
Agustin
Imac G5
Started compilation: Fri Jul 28 00:49:21 CEST 2006
Errors in:
/Users/agus/grass6/lib/gmath
/Users/agus/grass6/lib/imagery
/Users/agus/grass6/lib/rst/interp_float
/Users/agus/grass6/general/g.transform
/Users/agus/grass6/imagery/i.class
/Users/agus/grass6/imagery/i.cluster
/Users/agus/grass6/imagery/i.gensig
/Users/agus/grass6/imagery/i.gensigset
/Users/agus/grass6/imagery/i.group
/Users/agus/grass6/imagery/i.his.rgb
/Users/agus/grass6/imagery/i.maxlik
/Users/agus/grass6/imagery/i.ortho.photo/libes
/Users/agus/grass6/imagery/i.ortho.photo/menu
/Users/agus/grass6/imagery/i.ortho.photo/photo.2image
/Users/agus/grass6/imagery/i.ortho.photo/photo.2target
/Users/agus/grass6/imagery/i.ortho.photo/photo.camera
/Users/agus/grass6/imagery/i.ortho.photo/photo.elev
/Users/agus/grass6/imagery/i.ortho.photo/photo.init
/Users/agus/grass6/imagery/i.ortho.photo/photo.rectify
/Users/agus/grass6/imagery/i.ortho.photo/photo.target
/Users/agus/grass6/imagery/i.points
/Users/agus/grass6/imagery/i.rectify
/Users/agus/grass6/imagery/i.rgb.his
/Users/agus/grass6/imagery/i.smap/shapiro
/Users/agus/grass6/imagery/i.target
/Users/agus/grass6/imagery/i.vpoints
/Users/agus/grass6/imagery/i.pca
/Users/agus/grass6/imagery/i.cca
/Users/agus/grass6/imagery/i.fft
/Users/agus/grass6/imagery/i.ifft
/Users/agus/grass6/imagery/i.zc
/Users/agus/grass6/ps/ps.map
/Users/agus/grass6/raster/r.param.scale
/Users/agus/grass6/raster/r.resamp.rst
/Users/agus/grass6/raster/simwe/simlib
/Users/agus/grass6/raster/simwe/r.sim.water
/Users/agus/grass6/raster/simwe/r.sim.sediment
/Users/agus/grass6/raster/r.in.gdal
/Users/agus/grass6/raster/r.surf.fractal
/Users/agus/grass6/vector/v.kernel
/Users/agus/grass6/vector/v.surf.rst
81-202-194-12:/Users/agus/grass6/lib/gmath root# make
cc -dynamiclib -flat_namespace -compatibility_version 6.1 -
current_version 6.1 -install_name /usr/local/grass-6.1.cvs/lib/
libgrass_gmath.dylib -o /Users/agus/grass6/dist.powerpc-apple-
darwin8.7.0/lib/libgrass_gmath.6.1.cvs.dylib -L/Users/agus/grass6/
dist.powerpc-apple-darwin8.7.0/lib -L/usr/local/grasslib/lib  -L/usr/
local/pgsql/lib   OBJ.powerpc-apple-darwin8.7.0/brent.o OBJ.powerpc-
apple-darwin8.7.0/dalloc.o OBJ.powerpc-apple-darwin8.7.0/del2g.o
OBJ.powerpc-apple-darwin8.7.0/eigen.o OBJ.powerpc-apple-darwin8.7.0/
eigen_tools.o OBJ.powerpc-apple-darwin8.7.0/fft.o OBJ.powerpc-apple-
darwin8.7.0/gauss.o OBJ.powerpc-apple-darwin8.7.0/getg.o OBJ.powerpc-
apple-darwin8.7.0/ialloc.o OBJ.powerpc-apple-darwin8.7.0/jacobi.o
OBJ.powerpc-apple-darwin8.7.0/la.o OBJ.powerpc-apple-darwin8.7.0/lu.o
OBJ.powerpc-apple-darwin8.7.0/max_pow2.o OBJ.powerpc-apple-
darwin8.7.0/mult.o OBJ.powerpc-apple-darwin8.7.0/rand1.o OBJ.powerpc-
apple-darwin8.7.0/svd.o -lgrass_gis -lgrass_datetime -lz    -
lfftw3    && if [ -z "" ] ; then ln -f -s libgrass_gmath.
6.1.cvs.dylib /Users/agus/grass6/dist.powerpc-apple-darwin8.7.0/lib/
libgrass_gmath.dylib; fi
ld: Undefined symbols:
_fftw2d_create_plan
_fftwnd_destroy_plan
_fftwnd_one
/usr/bin/libtool: internal link edit command failed
make: *** [/Users/agus/grass6/dist.powerpc-apple-darwin8.7.0/lib/
libgrass_gmath.6.1.cvs.dylib] Error 1
Agustin
On 26/07/2006, at 01:52 AM, Michael Barton wrote:
> Well,
> I had a few bits of time and squeezed in a couple of attempts to
> recompile
> GRASS for Mac OSX PPC.
> In the end, I reverted to Lorenzo Moretti's libraries and the
> configure
> script that had worked before with them.
> GRASS compiles, but has errors in d.path, d.vect, and v.digit
> (these are new
> since my last attempt at compiling last week). It also has errors
> in reading
> the makefile for gism and dm (these have occurred every time and
> refer to a
> problem with the last line of make for these 2 modules). I'll put
> the errors
> I get when trying to recompile each of the offending modules below.
> But first I want to report on the results. GRASS starts and seems
> to work
> fine. But...
> rasters won't display in the TclTk canvas. Vectors will display,
> but rasters
> won't. They are present (I can test with r.what), but you can't see
> them.
> I'm pretty sure that it has to do with transparency, mask, or the
> like in
> the PNG driver. Have there been any very recent changes that might
> affect
> this?
> NVIZ is still broken, even in the x11 version (which is what I
> compiled).
> v.digit has the reported bugs--which it doesn't have when runing
> Lorenzo's
> 10 June binaries on my laptop.
> Here are the compilation errors. I've rerun make for each module that
> reported an error and list the results below. I have no idea what's
> wrong.
> The frustrating thing is that it has gotten progressively worse
> each time I
> update and compile over the past 2 weeks--and I've tried make
> clean's. Any
> suggestion would be welcome. If I'm the only one with a problem, then
> hopefully someone can help sort it out. But I'm worried that others
> might be
> having similar issues with the current cvs version for Mac.
> Michael
> GRASS GIS compilation log
> Started compilation: Tue Jul 25 12:52:38 MST 2006
> Errors in:
> /Users/cmbarton/grass_dev/grass6/display/d.path
> /Users/cmbarton/grass_dev/grass6/display/d.vect
> /Users/cmbarton/grass_dev/grass6/gui/tcltk/d.m
> /Users/cmbarton/grass_dev/grass6/gui/tcltk/gis.m
> /Users/cmbarton/grass_dev/grass6/vector/v.digit
> D.PATH
> anthgradpc7:~/grass_dev/grass6/display cmbarton$ cd d.path
> anthgradpc7:~/grass_dev/grass6/display/d.path cmbarton$ make
> gcc -L/Users/cmbarton/grass_dev/grass6/dist.powerpc-apple-
> darwin8.7.0/lib
> -L/usr/local/grasslib/lib  -L/usr/local/pgsql/lib
> -I/usr/local/grasslib/include     -DPACKAGE=\""grassmods"\" -o
> /Users/cmbarton/grass_dev/grass6/dist.powerpc-apple-darwin8.7.0/bin/
> d.path
> OBJ.powerpc-apple-darwin8.7.0/main.o OBJ.powerpc-apple-darwin8.7.0/
> select.o
> -lgrass_display -lgrass_raster -lgrass_vect -lgrass_dig2 -lgrass_dgl
> -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase
> -L/usr/local/grasslib/lib -lgdal -lgrass_dgl -lgrass_dbmiclient
> -lgrass_dbmibase  -lgrass_gis -lgrass_datetime -lz   -lintl  -lz
> /usr/bin/ld: warning prebinding disabled because dependent library:
> /Applications/Grass/grass61cvs.app/Contents/Resources/grass-6.1.cvs/
> lib/libg
> rass_display.dylib is not prebound
> /usr/bin/ld: multiple definitions of symbol _trans
> /Users/cmbarton/grass_dev/grass6/dist.powerpc-apple-darwin8.7.0/lib/
> libgrass
> _raster.dylib(com_io.o) definition of _trans
> libgrass
> _gis.dylib(icon.o) definition of _trans
> collect2: ld returned 1 exit status
> make: ***
> [/Users/cmbarton/grass_dev/grass6/dist.powerpc-apple-darwin8.7.0/
> bin/d.path]
> Error 1
> D.VECT
> anthgradpc7:~/grass_dev/grass6/display cmbarton$ cd d.vect
> anthgradpc7:~/grass_dev/grass6/display/d.vect cmbarton$ make
> darwin8.7.0/lib
> d.vect
> OBJ.powerpc-apple-darwin8.7.0/area.o OBJ.powerpc-apple-darwin8.7.0/
> attr.o
> OBJ.powerpc-apple-darwin8.7.0/dir.o OBJ.powerpc-apple-darwin8.7.0/
> label.o
> plot1.o
> OBJ.powerpc-apple-darwin8.7.0/topo.o OBJ.powerpc-apple-darwin8.7.0/
> zcoor.o
> -L/usr/local/grasslib/lib -lgdal -lgrass_dbmiclient -lgrass_dbmibase
> -lgrass_gis -lgrass_datetime -lz   -lintl -lgrass_symb  -lz
> lib/libg
> libgrass
> libgrass
> /usr/bin/ld: warning suggest use of -bind_at_load, as lazy binding may
> result in errors or different symbols being used
> symbol _trans used from dynamic library
> libgrass
> _gis.dylib(icon.o) not from earlier dynamic library
> lib/libg
> rass_raster.dylib(com_io.o)
> make: ***
> bin/d.vect]
> Error 1
> V.DIGIT
> anthgradpc7:~/grass_dev/grass6/vector cmbarton$ cd v.digit
> anthgradpc7:~/grass_dev/grass6/vector/v.digit cmbarton$ make
> darwin8.7.0/lib
> -L/usr/local/grasslib/lib  -L/usr/local/pgsql/lib    -I/usr/X11R6/
> include
> -I/usr/local/grasslib/include -I/usr/local/grasslib/include
> v.digit
> OBJ.powerpc-apple-darwin8.7.0/attr.o
> OBJ.powerpc-apple-darwin8.7.0/background.o
> OBJ.powerpc-apple-darwin8.7.0/c_face.o OBJ.powerpc-apple-
> darwin8.7.0/cat.o
> OBJ.powerpc-apple-darwin8.7.0/centre.o
> OBJ.powerpc-apple-darwin8.7.0/display.o
> OBJ.powerpc-apple-darwin8.7.0/driver.o
> OBJ.powerpc-apple-darwin8.7.0/i_face.o OBJ.powerpc-apple-
> darwin8.7.0/line.o
> symb.o
> OBJ.powerpc-apple-darwin8.7.0/util.o OBJ.powerpc-apple-darwin8.7.0/
> var.o
> OBJ.powerpc-apple-darwin8.7.0/vertex.o OBJ.powerpc-apple-
> darwin8.7.0/zoom.o
> -lgrass_D -lgrass_display -lgrass_raster -lgrass_vect -lgrass_dig2
> -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -
> lgrass_dbmibase
> -L/usr/local/grasslib/lib -lgdal -lgrass_form -lgrass_gis -
> lgrass_datetime
> -lz   -lintl -L/usr/local/grasslib/lib -ltk8.4   -ltcl8.4   -lz
> lib/libg
> rass_D.dylib is not prebound
> libgrass
> libgrass
> libgrass
> lib/libg
> make: ***
> bin/v.digit
> ] Error 1
> GIS.M
> anthgradpc7:~/grass_dev/grass6/gui/tcltk cmbarton$ cd gis.m
> anthgradpc7:~/grass_dev/grass6/gui/tcltk/gis.m cmbarton$ make
> GISRC=/Users/cmbarton/grass_dev/grass6/dist.powerpc-apple-
> darwin8.7.0/demolo
> cation/.grassrc61
> GISBASE=/Users/cmbarton/grass_dev/grass6/dist.powerpc-apple-
> darwin8.7.0
> PATH=/Users/cmbarton/grass_dev/grass6/dist.powerpc-apple-
> darwin8.7.0/bin:$PA
> TH
> DYLD_LIBRARY_PATH="/Users/cmbarton/grass_dev/grass6/dist.powerpc-
> apple-darwi
> n8.7.0/lib:"
> scripts/gis.
> m --html-description | grep -v '</body>\|</html>' >
> gis.m.tmp.html ; true
> mkdir -p
> docs/html
> mv -f gis.m.tmp.html
> docs/html/gi
> s.m.html
> for file in  *.png *.jpg ; do \
>         head -n 1 $file | grep '^#!' > /dev/null ; \
>         if [ $? -ne 0 ] ; then \
>            /usr/bin/install -c  -m 644 $file
> docs/html ;
>         fi \
>         done 2> /dev/null ; true
> if [ ! -d
> scripts ] ;
> then mkdir -p
> scripts; fi
> /usr/bin/install -c  -m 755 gis.m
> scripts
> if [ ! -d
> /Users/cmbarton/grass_dev/grass6/dist.powerpc-apple-darwin8.7.0/etc/
> gm ] ;
> then mkdir -p
> gm; fi
> if [ ! -d
> gm/scrip
> t/ ] ; then mkdir -p
> gm/scrip
> t/ ; fi
> /usr/bin/install -c  -m 755 *.tcl
> /Users/cmbarton/grass_dev/grass6/dist.powerpc-apple-darwin8.7.0/etc/gm
> /usr/bin/install -c  -m 644 *.gif
> /usr/bin/install -c  -m 755 script/*.*
> gm/scrip
> t
> install: script/CVS.sandboxinfo: Inappropriate file type or format
> make: *** [default] Error 71
> D.M
> anthgradpc7:~/grass_dev/grass6/gui/tcltk cmbarton$ cd d.m
> anthgradpc7:~/grass_dev/grass6/gui/tcltk/d.m cmbarton$ make
> darwin8.7.0/demolo
> cation/.grassrc61
> darwin8.7.0
> darwin8.7.0/bin:$PA
> TH
> apple-darwi
> n8.7.0/lib:"
> scripts/d.m
> --html-description | grep -v '</body>\|</html>' > d.m.tmp.html ; true
> mkdir -p
> docs/html
> mv -f d.m.tmp.html
> docs/html/d.
> m.html
> docs/html ;
>         fi \
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: William Kyngesburye <woklist at kyngchaos.com>
>> Reply-To: William Kyngesburye <kyngchaos at kyngchaos.com>
>> Date: Sun, 23 Jul 2006 13:00:52 -0500
>> To: Michael Barton <michael.barton at asu.edu>, <grass-
>> bugs at intevation.de>
>> Cc: <grass-dev at grass.itc.it>
>> Subject: Re: [bug #4768] (grass) nviz segfault on startup when
>> On Jul 23, 2006, at 12:33 PM, Michael Barton via RT wrote:
>>> William,
>>> This is great news.
>>> Could you send me the details of how you set this up and
>>> configured it
>>> (including your list of configure flags) so that I can duplicate
>>> it? I won't
>>> be able to do it until at least Tuesday or maybe Wednesday, so
>>> there is no
>>> hurry. But I'd like to try it to see if I can do it too.
>> Actually, simple standard stuff for configuration.  In addition to
>> setting includes/libs options for the various graphics, GIS and DB
>> libraries, these are the important settings:
>> --with-tcltk-includes=/usr/local/grasslibs/include \
>> --with-tcltk-libs=/usr/local/grasslibs/lib \
>> --with-x --without-motif --without-glw --with-opengl=x11
>> I suppose with an X11-only build like this, you could add motif and
>> glw.  This example assumes an X11 tcltk build in /usr/local/
>> grasslibs, which is where I installed mine.  I think Lorenzo uses
>> 'grasslib', without the plural, so you could try his tcltk.  Or build
>> your own wherever you like, but I suggest an isolated location like
>> this so other alternate builds of GRASS (ie Aqua) don't get
>> confused.  ie, if you build the X11 tcltk in /usr/X11R6, an Aqua
>> build of GRASS that includes X11 support might pick up the X11 tcltk
>> at link time, not the Aqua version.
>> Which brings me to the key here with TclTk - I think the X11 NVIZ
>> crash is because of GRASS getting accidentally linked to Apple's Aqua
>> TclTk (which is quite old BTW, 8.4.7) instead of the intended X11
>> TclTk.  I guess one thing to do is make sure you use --with-tcltk-
>> libs=.  And in my case, I had a broken X11 TclTk install, so even
>> then it didn't link to it until I fixed it.  If a -L/usr/lib gets
>> somehow inserted in the link step before -L/path/to/your/X11/tcltk/
>> lib, that could cause it to grab Apple's TclTk.
>> A way to check if it linked right is to use otool:
>> $ otool -L /usr/local/grass-6.1.cvs/bin/nviz
>> (or you can check the nviz binary in the grass source/dist/bin before
>> make install)
>> This will list all the library paths nviz needs.  Make sure tcl and
>> tk libs have the right paths.  Fixing it is another matter, but
>> hopefully it will be right the first time.
>> http://www.kyngchaos.com/
>> First Pogril: Why is life like sticking your head in a bucket filled
>> with hyena offal?
>> Second Pogril: I don't know.  Why IS life like sticking your head in
>> a bucket filled with hyena offal?
>> First Pogril: I don't know either.  Wretched, isn't it?
>> -HitchHiker's Guide to the Galaxy
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
