[GRASS-dev] maybe bugs
    Martin Wegmann
    wegmann at biozentrum.uni-wuerzburg.de
    Fri Jul 28 09:36:27 EDT 2006
On Thursday 27 July 2006 19:41, Maciej Sieczka wrote:
> Martin Wegmann napisa?(a):
> >> Maybe this explains: gis.m doesn't read nor write to the WIND file,
> >> while d.zoom/g.region do. What you change with d.zoom/g.region will not
> >> affect gis.m display (unless you press 'Zoom to current region' from
> >> gis.m menu) and vice versa: if you zoom/pan in the gis.m canvas it will
> >> not affect WIND file, ie. current region settings. Check with g.region
> >> -p for yourself.
> > it means, if I zoom into a region with gis.m and say 'g.region save=XX'
> > in the CLI and afterwards "zoom to .. region" it won't work - I tried it
> > - well it does not make sense for me who is working on the CLI and GUI.
> > How do I define a new region, if gis.m and g.region does not talk to each
> > other?
> There is a 'Set current region (WIND file) to match display' in the
> 'Zoom to...' menu. I haven't used it ever (I'm using gis.m very little
> at all), but I guess it's for such purpose (I only wonder how it behaves
> in different drawing modes ('Constrain map to region geometry' and 'Map
> filles display window') as well as if it doesn't have problems with
> resolution allignment. Please give a try and report back if you don't mind.
'Set current region (WIND file) to match display' sets the current extend
to "current region"
Selecting "zoom to current region" zoomes into the previously displayed area.
it works well after I understood gis.m, however how do I do "g.region save=  "
in gis.m?
Is it planned to solve the lacking interaction between CLI g.region and gis.m?
e.g. doing 'g.region region=africa' in the CLI and refresh the monitor does
not work
or
zooming in with gis.m - doing g.region save in CLI - zoom to saved region in
gis.m does not work
> >>> zoom into map
> >>> zoom out: very elongated rectangle
> >>> map becomes smaller but is squeezed to one border (depending of the
> >>> orientation of the elongated rectangle)
> >> In of gis.m you have drawing modes:
> >> Map filles display window
> >> The first mode behaves pretty much like d.zoom (only it doesn't modify
> >> WIND file), the latter is maybe what you are looking for.
> > thanks, now I found the buttons on the right hand side - ,-)
> > well but it does not explain why the visible extend (white space vs. grey
> > background) becomes smaller and smaller (by zooming out with very
> > elongated rectangle) when selecting "constrain map to region geometry",
> > does it?
> You propably have a point here. Michael?
> >> I suppose this is all your missundersting of region handling in gis.m.
> > hmm, probably, thanks so far; I think I have to become more accustomed to
> > gis.m.
> Honestly - me too :).
thanks so far, cheers, Martin
