[GRASS-dev] [bug #4926] (grass) d.grid and g.parser (wish)
Request Tracker
grass-bugs at intevation.de
Sat Jul 29 20:46:26 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4926
Subject: d.grid and g.parser (wish)
Model: PowerMac8,2, BootROM 5.2.5f1, 1 processors, PowerPC G5 (3.0), 2 GHz, 1 GB
Graphics: ATI Radeon 9600, ATY,RV351, AGP, 128 MB
Memory Module: DIMM0/J4000, 1 GB, DDR SDRAM, PC3200U-30330
_______________________________________
I got these two errors once in a while.
Today's cvs compiled from source
Command: d.grid
Path: /usr/local/grass-6.1.cvs/bin/d.grid
Parent: wish [18796]
Version: ??? (???)
PID: 18994
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000044
Thread 0 Crashed:
0 libgrass_raster.dylib 0x00024080 R_reset_color + 28 (com_proto.c:187)
1 libgrass_display.dylib 0x00010254 D_translate_or_add_color + 312
(tran_colr.c:92)
2 libgrass_display.dylib 0x000102a4 D_parse_color + 56 (tran_colr.c:126)
3 d.grid 0x00002524 main + 648 (main.c:130)
4 d.grid 0x00001ae8 _start + 348 (crt.c:272)
5 d.grid 0x00001988 start + 60
Thread 0 crashed with PPC Thread State 64:
srr0: 0x0000000000024080 srr1: 0x100000000200d030
vrsave: 0x0000000000000000
cr: 0x22000442 xer: 0x0000000000000000 lr: 0x0000000000010254
ctr: 0x0000000000024064
r0: 0x0000000000010254 r1: 0x00000000bfffe900 r2: 0x000000000002a48c
r3: 0x0000000000000000
r4: 0x0000000000000099 r5: 0x0000000000000099 r6: 0x000000000000000f
r7: 0x000000000ccccccc
r8: 0x00000000bfffe42b r9: 0x0000000000000000 r10: 0x000000000002406c
r11: 0x0000000044000442
r12: 0x0000000000024064 r13: 0x0000000000000000 r14: 0x0000000000000000
r15: 0x0000000000000000
r16: 0x0000000000000000 r17: 0x0000000000000000 r18: 0x0000000000000000
r19: 0x0000000000000000
r20: 0x0000000000601220 r21: 0x00000000006011c0 r22: 0x00000000004965a0
r23: 0x00000000006010f0
r24: 0x0000000000601090 r25: 0x00000000006012a0 r26: 0x000000000000000f
r27: 0x00000000bfffe944
r28: 0x00000000004959d4 r29: 0x00000000004959d0 r30: 0x0000000000000010
r31: 0x0000000000010124
Binary Images Description:
0x1000 - 0x4fff d.grid /usr/local/grass-6.1.cvs/bin/d.grid
0xb000 - 0x11fff libgrass_display.dylib
/usr/local/grass-6.1.cvs/lib/libgrass_display.dylib
0x23000 - 0x29fff libgrass_raster.dylib
/usr/local/grass-6.1.cvs/lib/libgrass_raster.dylib
0x3d000 - 0x3ffff libgrass_pngdriver.dylib
/usr/local/grass-6.1.cvs/lib/libgrass_pngdriver.dylib
0x4c000 - 0x55fff libgrass_driver.dylib
/usr/local/grass-6.1.cvs/lib/libgrass_driver.dylib
0x6a000 - 0x6ffff libgrass_gproj.dylib
/usr/local/grass-6.1.cvs/lib/libgrass_gproj.dylib
0x7a000 - 0x80fff libgrass_datetime.dylib
/usr/local/grass-6.1.cvs/lib/libgrass_datetime.dylib
0x8d000 - 0xb4fff libpng.3.dylib /usr/local/grasslib/lib/libpng.3.dylib
0xbc000 - 0xd1fff libpq.3.dylib /usr/local/pgsql/lib/libpq.3.dylib
0x205000 - 0x22cfff libproj.0.dylib /usr/local/lib/libproj.0.dylib
0x452000 - 0x494fff libgrass_gis.dylib
/usr/local/grass-6.1.cvs/lib/libgrass_gis.dylib
0x1008000 - 0x12f0fff libgdal.1.dylib /usr/local/lib/libgdal.1.dylib
0x8fe00000 - 0x8fe52fff dyld 45.1 /usr/lib/dyld
0x90000000 - 0x901bbfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90213000 - 0x90218fff libmathCommon.A.dylib
/usr/lib/system/libmathCommon.A.dylib
0x907b9000 - 0x90892fff com.apple.CoreFoundation 6.4.6 (368.27)
/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x908db000 - 0x908dbfff com.apple.CoreServices 10.4 (???)
/System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x908dd000 - 0x909dffff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a39000 - 0x90abdfff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90ae7000 - 0x90b57fff com.apple.framework.IOKit 1.4 (???)
/System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90b6d000 - 0x90b7ffff libauto.dylib /usr/lib/libauto.dylib
0x90b86000 - 0x90e5dfff com.apple.CoreServices.CarbonCore 681.4
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90ec3000 - 0x90f43fff com.apple.CoreServices.OSServices 4.1
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f8d000 - 0x90fcefff com.apple.CFNetwork 129.16
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90fe3000 - 0x90ffbfff com.apple.WebServices 1.1.2 (1.1.0)
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x9100b000 - 0x9108cfff com.apple.SearchKit 1.0.5
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x910d2000 - 0x910fcfff com.apple.Metadata 10.4.4 (121.36)
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9110d000 - 0x9111bfff libz.1.dylib /usr/lib/libz.1.dylib
0x9111e000 - 0x912d8fff com.apple.security 4.4 (27566)
/System/Library/Frameworks/Security.framework/Versions/A/Security
0x913d6000 - 0x913dffff com.apple.DiskArbitration 2.1
/System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913e6000 - 0x9140efff com.apple.SystemConfiguration 1.8.3
/System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91421000 - 0x9142cfff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x91a0b000 - 0x91ad3fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x92d65000 - 0x92e53fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x936e3000 - 0x93703fff libmx.A.dylib /usr/lib/libmx.A.dylib
0x94ac9000 - 0x94b3afff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x94ed0000 - 0x94efffff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
0x94f0f000 - 0x94f2cfff libresolv.9.dylib /usr/lib/libresolv.9.dylib
0x95431000 - 0x9555ffff edu.mit.Kerberos 5.5.23
/System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
Date/Time: 2006-07-30 02:30:35.509 +0200
OS Version: 10.4.7 (Build 8J135)
Report Version: 4
Command: wish
Path: /usr/local/grasslib/bin/wish
Parent: g.parser [22577]
Version: ??? (???)
PID: 22578
Thread: 0
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000048
Thread 0 Crashed:
0 libtk8.4.dylib 0x0b0267bc RecomputePlacement + 584 (icplusplus.c:27)
1 libtcl8.4.dylib 0x0a0693f4 TclServiceIdle + 104 (icplusplus.c:27)
2 libtcl8.4.dylib 0x0a0585b4 Tcl_DoOneEvent + 384 (icplusplus.c:27)
3 libtk8.4.dylib 0x0b00b780 Tk_UpdateObjCmd + 204 (icplusplus.c:27)
4 libtcl8.4.dylib 0x0a00edf0 TclEvalObjvInternal + 668 (icplusplus.c:27)
5 libtcl8.4.dylib 0x0a032c88 TclExecuteByteCode + 2396 (icplusplus.c:27)
6 libtcl8.4.dylib 0x0a032278 TclCompEvalObj + 376 (icplusplus.c:27)
7 libtcl8.4.dylib 0x0a062904 TclObjInterpProc + 800 (icplusplus.c:27)
8 libtcl8.4.dylib 0x0a00edf0 TclEvalObjvInternal + 668 (icplusplus.c:27)
9 libtcl8.4.dylib 0x0a00f6a0 Tcl_EvalEx + 372 (icplusplus.c:27)
10 libtcl8.4.dylib 0x0a020558 TraceVarProc + 416 (icplusplus.c:27)
11 libtcl8.4.dylib 0x0a0717ac CallVarTraces + 568 (icplusplus.c:27)
12 libtcl8.4.dylib 0x0a06f010 TclPtrSetVar + 940 (icplusplus.c:27)
13 libtcl8.4.dylib 0x0a033578 TclExecuteByteCode + 4684 (icplusplus.c:27)
14 libtcl8.4.dylib 0x0a032278 TclCompEvalObj + 376 (icplusplus.c:27)
15 libtcl8.4.dylib 0x0a062904 TclObjInterpProc + 800 (icplusplus.c:27)
16 libtcl8.4.dylib 0x0a00edf0 TclEvalObjvInternal + 668 (icplusplus.c:27)
17 libtcl8.4.dylib 0x0a032c88 TclExecuteByteCode + 2396 (icplusplus.c:27)
18 libtcl8.4.dylib 0x0a032278 TclCompEvalObj + 376 (icplusplus.c:27)
19 libtcl8.4.dylib 0x0a062904 TclObjInterpProc + 800 (icplusplus.c:27)
20 libtcl8.4.dylib 0x0a00edf0 TclEvalObjvInternal + 668 (icplusplus.c:27)
21 libtcl8.4.dylib 0x0a032c88 TclExecuteByteCode + 2396 (icplusplus.c:27)
22 libtcl8.4.dylib 0x0a032278 TclCompEvalObj + 376 (icplusplus.c:27)
23 libtcl8.4.dylib 0x0a062904 TclObjInterpProc + 800 (icplusplus.c:27)
24 libtcl8.4.dylib 0x0a00edf0 TclEvalObjvInternal + 668 (icplusplus.c:27)
25 libtcl8.4.dylib 0x0a032c88 TclExecuteByteCode + 2396 (icplusplus.c:27)
26 libtcl8.4.dylib 0x0a032278 TclCompEvalObj + 376 (icplusplus.c:27)
27 libtcl8.4.dylib 0x0a00fbf8 Tcl_EvalObjEx + 436 (icplusplus.c:27)
28 libtcl8.4.dylib 0x0a016d30 Tcl_IfObjCmd + 492 (icplusplus.c:27)
29 libtcl8.4.dylib 0x0a00edf0 TclEvalObjvInternal + 668 (icplusplus.c:27)
30 libtcl8.4.dylib 0x0a032c88 TclExecuteByteCode + 2396 (icplusplus.c:27)
31 libtcl8.4.dylib 0x0a032278 TclCompEvalObj + 376 (icplusplus.c:27)
32 libtcl8.4.dylib 0x0a062904 TclObjInterpProc + 800 (icplusplus.c:27)
33 libtcl8.4.dylib 0x0a00edf0 TclEvalObjvInternal + 668 (icplusplus.c:27)
34 libtcl8.4.dylib 0x0a032c88 TclExecuteByteCode + 2396 (icplusplus.c:27)
35 libtcl8.4.dylib 0x0a032278 TclCompEvalObj + 376 (icplusplus.c:27)
36 libtcl8.4.dylib 0x0a00fbf8 Tcl_EvalObjEx + 436 (icplusplus.c:27)
37 libtcl8.4.dylib 0x0a0472dc TclChannelEventScriptInvoker + 56
(icplusplus.c:27)
38 libtcl8.4.dylib 0x0a046ce4 Tcl_NotifyChannel + 340 (icplusplus.c:27)
39 libtcl8.4.dylib 0x0a07b9e4 FileHandlerEventProc + 124 (icplusplus.c:27)
40 libtcl8.4.dylib 0x0a0581d0 Tcl_ServiceEvent + 164 (icplusplus.c:27)
41 libtcl8.4.dylib 0x0a0585a0 Tcl_DoOneEvent + 364 (icplusplus.c:27)
42 libtk8.4.dylib 0x0b012908 Tk_MainLoop + 56 (icplusplus.c:27)
43 libtk8.4.dylib 0x0b01efd8 Tk_MainEx + 1372 (icplusplus.c:27)
44 wish 0x000055d4 main + 60 (crt.c:300)
45 wish 0x00005088 _start + 392 (crt.c:267)
46 dyld 0x8fe01048 _dyld_start + 60
Thread 1:
0 libSystem.B.dylib 0x9001f7ac select + 12
1 libtcl8.4.dylib 0x0a07bed4 NotifierThreadProc + 412 (icplusplus.c:27)
2 libSystem.B.dylib 0x9002bc28 _pthread_body + 96
srr0: 0x000000000b0267bc srr1: 0x100000000000f030
cr: 0x28002452 xer: 0x0000000020000000 lr: 0x000000000b0269c0
ctr: 0x00000000900014e8
r0: 0x0000000000000000 r1: 0x00000000bfffc4c0 r2: 0x0000000000000000
r3: 0x0000000000000001
r4: 0x00000000004f2708 r5: 0x0000000000000000 r6: 0x0000000000000000
r7: 0x0000000000000000
r8: 0x0000000000000000 r9: 0x0000000043300000 r10: 0x000000000000022c
r11: 0x0000000000000000
r12: 0x00000000900014e8 r13: 0x0000000000010408 r14: 0x0000000000000000
r16: 0x0000000000000000 r17: 0x0000000000000032 r18: 0x0000000000000000
r20: 0x0000000000000000 r21: 0x0000000000000000 r22: 0x0000000000000000
r23: 0x0000000000000001
r24: 0x0000000000019078 r25: 0x0000000000000000 r26: 0x0000000000000000
r27: 0x0000000000000000
r28: 0x000000000000035c r29: 0x00000000004f2a28 r30: 0x0000000000002004
r31: 0x000000000b026584
0x1000 - 0x5fff wish /usr/local/grasslib/bin/wish
0xa000000 - 0xa089fff libtcl8.4.dylib /usr/local/grasslib/lib/libtcl8.4.dylib
0xb000000 - 0xb0adfff libtk8.4.dylib /usr/local/grasslib/lib/libtk8.4.dylib
0x9c31c000 - 0x9c3e4fff libX11.6.dylib /usr/X11R6/lib/libX11.6.dylib
-------------------------------------------- Managed by Request Tracker
