[GRASS-dev] Re: [bug #4924] (grass) missing quoted path vars in
	init.sh
    Markus Neteler
    neteler at itc.it
    Sun Jul 30 17:09:56 EDT 2006
Maybe the list has an idea. Can't be too hard.
http://intevation.de/rt/webrt?serial_num=4924&display=History
Markus
On Sun, Jul 30, 2006 at 04:08:08PM -0500, William Kyngesburye wrote:
> Would that happen even when no monitors are open?  Where is the
> monitor lockfile stored?  not the application folder, maybe the grass
> DB?  That wouldn't have an affect on this case, since the DB has no
> spaces in its pathname.
> d.mon is using the path to something in the GRASS application.  Even
> before quitting GRASS, I can't do anything with d.mon - 'd.mon -L' as
> in the exit code, 'd.mon x0', 'd.mon', all give that error:
> sh: line 1: /Users/kyngchaos/Applications/0Untitled: No such file or
> directory
> Should this bug be expanded/renamed to a more general path var
> quoting issue?  - search out issues like d.mon in commands, and
> include the same problem in gis.m/tcl?
> >The problem when closing monitors is related to d.mon.
> >Apparently something isn't quoted properly to allow for
> >spaces in the lock file name of the monitor (or similar).
