[GRASS-dev] [bug #4931] (grass) not able to start
Request Tracker grass-bugs at intevation.de
Mon Jul 31 02:05:06 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4931
Subject: not able to start
Platform: WindowsNT/2000/XP
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 6.0.1
following is the Xwin log report:
(II) XF86Config is not supported
(II) See http://x.cygwin.com/docs/faq/cygwin-x-faq.html for more information
winAdjustVideoModeShadowGDI - Using Windows display depth of 16 bits per pixel
winAllocateFBShadowGDI - Creating DIB with width: 800 height: 600 depth: 16
winInitVisualsShadowGDI - Masks 0000f800 000007e0 0000001f BPRGB 6 d 16 bpp 16
null screen fn ReparentWindow
null screen fn RestackWindow
InitQueue - Calling pthread_mutex_init
InitQueue - pthread_mutex_init returned
InitQueue - Calling pthread_cond_init
InitQueue - pthread_cond_init returned
winInitMultiWindowWM - Hello
winInitMultiWindowWM - Calling pthread_mutex_lock ()
winMultiWindowXMsgProc - Hello
winMultiWindowXMsgProc - Calling pthread_mutex_lock ()
MIT-SHM extension disabled due to lack of kernel support
XFree86-Bigfont extension local-client optimization disabled due to lack of shared memory support in the kernel
(--) Setting autorepeat to delay=250, rate=15
(--) winConfigKeyboard - Layout: "00000409" (00000409)
(--) Using preset keyboard for "English (USA)" (409), type "4"
(--) 3 mouse buttons found
Could not init font path element /usr/X11R6/lib/X11/fonts/TTF/, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/Type1/, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/CID/, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/100dpi/, removing from list!
winInitMultiWindowWM - pthread_mutex_lock () returned.
winProcEstablishConnection - Hello
winInitClipboard ()
winInitMultiWindowWM - pthread_mutex_unlock () returned.
winMultiWindowXMsgProc - pthread_mutex_lock () returned.
winClipboardProc - Hello
winProcEstablishConnection - winInitClipboard returned.
winInitMultiWindowWM - DISPLAY=127.0.0.1:0.0
winMultiWindowXMsgProc - pthread_mutex_unlock () returned.
DetectUnicodeSupport - Windows 95/98/Me
winMultiWindowXMsgProc - DISPLAY=127.0.0.1:0.0
winClipboardProc - DISPLAY=127.0.0.1:0.0
winInitMultiWindowWM - XOpenDisplay () returned and successfully opened the display.
winClipboardProc - XOpenDisplay () returned and successfully opened the display.
winProcSetSelectionOwner - Clipboard not yet started, aborting.
winMultiWindowXMsgProc - XOpenDisplay () returned and successfully opened the display.
Please give me solution about First Error message:"XF86conig is not supported"
-------------------------------------------- Managed by Request Tracker
