[GRASS-dev] [bug #4906] (grass) d.path segfaults after choosing first node
Moritz Lennert mlennert at club.worldonline.be
Mon Jul 31 05:19:15 EDT 2006
Markus Neteler via RT wrote:
> Moritz,
> it works just fine for me. Probably you need to do
> a full recompile (make distclean)?
Yep, that did it. Thanks. Bug can be closed.
Moritz
> v.net input=roads output=myroads2
> d.vect myroads2
> d.path myroads2
> # works.
> Note that there is a map 'roads_net' in the recent Spearfish
> packages, which was already made by v.net.
> Markus
> -------------------------------------------- Managed by Request Tracker
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
