[GRASS-dev] [bug #4920] (grass) nviz fails
Request Tracker grass-bugs at intevation.de
Fri Jul 28 13:32:00 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4920
Subject: nviz fails
Platform: Mac PowerPC 64-bit
grass obtained from: CVS
grass binary for platform: Compiled from Sources
grass6/dist.powerpc-apple-darwin8.7.0/bin/nviz 20264
Exception:  EXC_BAD_ACCESS (0x0001)
Codes:      KERN_INVALID_ADDRESS (0x0001) at 0x7372635c
unable to open symbol file: /usr/local/grass-6.1.cvs/lib/libgrass_ogsf.dylib:
No such file or directory.
warning: Unable to read symbols from
"/usr/local/grass-6.1.cvs/lib/libgrass_ogsf.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_ogsf.dylib"; skipping.
/usr/local/grass-6.1.cvs/lib/libgrass_bitmap.dylib: No such file or directory.
"/usr/local/grass-6.1.cvs/lib/libgrass_bitmap.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_bitmap.dylib"; skipping.
unable to open symbol file: /usr/local/grass-6.1.cvs/lib/libgrass_linkm.dylib:
"/usr/local/grass-6.1.cvs/lib/libgrass_linkm.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_linkm.dylib"; skipping.
unable to open symbol file: /usr/local/grass-6.1.cvs/lib/libgrass_vect.dylib:
"/usr/local/grass-6.1.cvs/lib/libgrass_vect.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_vect.dylib"; skipping.
unable to open symbol file: /usr/local/grass-6.1.cvs/lib/libgrass_dig2.dylib:
"/usr/local/grass-6.1.cvs/lib/libgrass_dig2.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_dig2.dylib"; skipping.
unable to open symbol file: /usr/local/grass-6.1.cvs/lib/libgrass_dgl.dylib:
"/usr/local/grass-6.1.cvs/lib/libgrass_dgl.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_dgl.dylib"; skipping.
unable to open symbol file: /usr/local/grass-6.1.cvs/lib/libgrass_rtree.dylib:
"/usr/local/grass-6.1.cvs/lib/libgrass_rtree.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_rtree.dylib"; skipping.
/usr/local/grass-6.1.cvs/lib/libgrass_dbmiclient.dylib: No such file or directory.
"/usr/local/grass-6.1.cvs/lib/libgrass_dbmiclient.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_dbmiclient.dylib"; skipping.
/usr/local/grass-6.1.cvs/lib/libgrass_dbmibase.dylib: No such file or directory.
"/usr/local/grass-6.1.cvs/lib/libgrass_dbmibase.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_dbmibase.dylib"; skipping.
unable to open symbol file: /usr/local/grass-6.1.cvs/lib/libgrass_sites.dylib:
"/usr/local/grass-6.1.cvs/lib/libgrass_sites.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_sites.dylib"; skipping.
unable to open symbol file: /usr/local/grass-6.1.cvs/lib/libgrass_form.dylib:
"/usr/local/grass-6.1.cvs/lib/libgrass_form.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_form.dylib"; skipping.
unable to open symbol file: /usr/local/grass-6.1.cvs/lib/libgrass_g3d.dylib:
"/usr/local/grass-6.1.cvs/lib/libgrass_g3d.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_g3d.dylib"; skipping.
unable to open symbol file: /usr/local/grass-6.1.cvs/lib/libgrass_gis.dylib:
"/usr/local/grass-6.1.cvs/lib/libgrass_gis.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_gis.dylib"; skipping.
/usr/local/grass-6.1.cvs/lib/libgrass_datetime.dylib: No such file or directory.
"/usr/local/grass-6.1.cvs/lib/libgrass_datetime.dylib".
"/usr/local/grass-6.1.cvs/lib/libgrass_datetime.dylib"; skipping.
Reading symbols for shared libraries ............... done
/Users/agus/20264: No such file or directory.
Attaching to program:
`/Users/agus/grass6/dist.powerpc-apple-darwin8.7.0/bin/nviz', process 20264.
done
0x9c335fc4 in XQueryExtension ()
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: KERN_INVALID_ADDRESS at address: 0x7372635c
(gdb) grass6/dist.powerpc-apple-darwin8.7.0/bin/nviz 20264
done
(gdb)
-------------------------------------------- Managed by Request Tracker
