[GRASS-dev] startup
Paul Kelly
paul-grass at stjohnspoint.co.uk
Mon Jul 31 11:06:25 EDT 2006
Hello everyone
To be honest I think the wording still confuses things a little. Simply
because it takes more than 2 or 3 words to explain the concepts of
location, mapset, region, co-ordinate system and GIS database. Perhaps
better to have minimal wording in the start-up screen and a more detailed
explanation in tool-tip help?
When I started using GRASS I hated how complicated it all was and how much
it made me think about my data and co-ordinate systems but now I really
appreciate that---because a thorough understanding of locations, regions
etc. is essential to ensuring you get meaningful results out of your GIS
analyses.
FWIW I don't think the text in the text-based start-up screen is too bad.
Here is my slightly improved version of it:
LOCATION: This is the name of a geographic location. It is defined by a
co-ordinate system and a rectangular boundary. -spearfish- is
the sample LOCATION provided with GRASS.
MAPSET: Every GRASS session runs under a particular MAPSET. Associated
with each MAPSET is a rectangular REGION and a set of maps.
DATABASE: This is the unix directory containing all the GRASS locations.
The REGION defaults to the entire area of the chosen LOCATION.
You may change it later with the command: g.region
Paul
On Mon, 31 Jul 2006, Markus Neteler wrote:
> Hi,
> Michael has made updates to the startup screen.
> The current state of the entrance screen can be seen
> here:
> http://mpa.itc.it/markus/tmp/new_grass61_startup_2.jpg
> (also valid for the release branch).
> Please comment on further modifications.
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
