[GRASS-dev] startup
Helena Mitasova
hmitaso at unity.ncsu.edu
Mon Jul 31 13:09:32 EDT 2006
Paul,
you are right - I forgot about that text - it is a pretty good, brief
description
polished by years of use. Maybe it could be added like this
Project Location
button ( named e.g. "info", "what it is", or something like that)
and when you click on it - the text from the old interface could pop up
in a separate
window if it is possible to do in TclTK, it can even be a more detailed
description
if needed.
I too find the new wording somewhat confusing, that is why I asked Markus
to post it for more feedback (it may be just me).
But there may be new users who have a completely different opinion so it
would be good
to hear from them.
Helena
Paul Kelly wrote:
> Hello everyone
> To be honest I think the wording still confuses things a little.
> Simply because it takes more than 2 or 3 words to explain the concepts
> of location, mapset, region, co-ordinate system and GIS database.
> Perhaps better to have minimal wording in the start-up screen and a
> more detailed explanation in tool-tip help?
> When I started using GRASS I hated how complicated it all was and how
> much
> it made me think about my data and co-ordinate systems but now I
> really appreciate that---because a thorough understanding of
> locations, regions etc. is essential to ensuring you get meaningful
> results out of your GIS analyses.
> FWIW I don't think the text in the text-based start-up screen is too
> bad. Here is my slightly improved version of it:
> LOCATION: This is the name of a geographic location. It is defined by a
> co-ordinate system and a rectangular boundary. -spearfish- is
> the sample LOCATION provided with GRASS.
> MAPSET: Every GRASS session runs under a particular MAPSET. Associated
> with each MAPSET is a rectangular REGION and a set of maps.
> DATABASE: This is the unix directory containing all the GRASS locations.
> The REGION defaults to the entire area of the chosen LOCATION.
> You may change it later with the command: g.region
> Paul
> On Mon, 31 Jul 2006, Markus Neteler wrote:
>> Hi,
>> Michael has made updates to the startup screen.
>> The current state of the entrance screen can be seen
>> here:
>> http://mpa.itc.it/markus/tmp/new_grass61_startup_2.jpg
>> (also valid for the release branch).
>> Please comment on further modifications.
>> Markus
>> grass-dev mailing list
>> grass-dev at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
Helena Mitasova
Department of Marine, Earth and Atmospheric Sciences
North Carolina State University
1125 Jordan Hall
NCSU Box 8208
Raleigh, NC 27695-8208
http://skagit.meas.ncsu.edu/~helena/
email: hmitaso at unity.ncsu.edu
ph: 919-513-1327 (no voicemail)
fax 919 515-7802
